Battery Recommendation - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 25th, 18, 10:38 AM Thread Starter
Kevin
Hi All, I am looking for an aftermarket battery for my 67. Not concerned with originality. Just looking for one that will fit. Any recommendations?
kmarron is offline
post #2 of 10 (permalink) Old Apr 25th, 18, 10:52 AM
Re: Battery Recommendation
You want a group 24 battery (that is the size of the case that fits in the battery box/tray you have now). The factory original group number was a 22F but they are hard to find today.
Big Dave
Larger Dave is online now
post #3 of 10 (permalink) Old Apr 25th, 18, 11:40 AM
Kevin
sleepsinshed's Avatar
I just replaced mine with this one and then put a topper on it.
Kevin
sleepsinshed is offline
post #4 of 10 (permalink) Old Apr 25th, 18, 12:27 PM Thread Starter
Kevin
Awesome thanks!!! just what I was looking for.
kmarron is offline
post #5 of 10 (permalink) Old Apr 25th, 18, 08:17 PM
Chris
I'd pop for an AGM battery as opposed to a flooded cell lead acid model. No spillage, leakage or boil-over.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #6 of 10 (permalink) Old Apr 25th, 18, 08:30 PM
scblucam's Avatar
I've been using Optima AGM for years and only a few problems. You still need to trickle charge them with an AGM ready charger if you don't drive frequently. Don't use a charger not ready for AGM.
68 302 M20 - 85 IROC Z
scblucam is online now
post #7 of 10 (permalink) Old Apr 26th, 18, 03:39 AM
Dom
68Tiger's Avatar
x2 Same battery replaced last year in my 69. Reason I went with it was the Napa warranty is better than most others I compared it to. BTW I found out that most but not all batteries are made by the same mfg. they are just labeled with the retailers label. During periods of non use I always keep it on a Noco Wicked Smart battery charger/maintainer.
1969 Camaro RS, 327ci, TH350 Automatic, Richmond 3:55 12 Bolt Posi, Norwood 11C build date. Recipient of December 2017 Team Camaro ROTM.
68Tiger is offline
post #8 of 10 (permalink) Old Apr 26th, 18, 07:02 PM
I can't help with a battery size, but I will say,make sure the cables and cable terminations are good. If you have the cheapo 99 cent ones that clamp onto a stripped cable end, throw them away and get better cables. Also too, if you are getting new cables, get cables that are of a decent gauge. The factory put in what they could to be minimally workable and if you have more cranking compression, more advanced timing, then larger cables should help.
SOA-Nova is online now
post #9 of 10 (permalink) Old Apr 27th, 18, 04:14 AM
kevin
got mine at walmart 7 years ago and still spins the engine like the day I bought it.
knock on wood
flat tire is offline
post #10 of 10 (permalink) Old Apr 27th, 18, 05:33 AM
Bruce
The majority of batteries are made by Johnson Electronics from Optima to Walmart. I have the Walmart 900 CCA in all 6 of my collector cars. They have a great warranty. FYI Johnson also makes Recarro seats and the majority of new car seats!!!!!
The Camaro Guy is offline
