adding a courtesy light - Team Camaro Tech
post #1 of 4 (permalink) Old May 4th, 18, 05:40 AM Thread Starter
kevin
68 Camaro. where do I pick up the hot wire that feeds the dome light and what color?
I want to add a led light for the passenger and driver side under the dash
flat tire is offline
post #2 of 4 (permalink) Old May 4th, 18, 05:51 AM
Re: adding a courtesy light
The hot wire is orange and you can pick it up where the rear harness goes under the driver side kick panel. The ground is white and switched by the jamb switches and can be picked up at the same place. Bulb holder needs to be fully isolated from the body.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 4 (permalink) Old May 4th, 18, 06:17 AM
Jonathon
Smitty68's Avatar
Along with Don AAW has a kit you can buy that has everything Kevin. The sockets wires etc. the only thing it doesnít have is the door switches.
https://www.americanautowire.com/sho...8aAhocEALw_wcB
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #4 of 4 (permalink) Old May 5th, 18, 04:55 AM Thread Starter
kevin
thanks for the replies
