Confused electronics. - Team Camaro Tech
post #1 of 5 (permalink) Old May 10th, 18, 01:30 PM Thread Starter
Robert
rtchaney's Avatar
When the driving and/or headlights are on, my left indicator light stays on on the dash. When I turn on the indicator to the left position, the dash indicator light flashes in opposition to the vehicles external turning indicators. The right ones are normal. I have done nothing in the dash but have wired a new electric fan recently.
1968, 5 speed, Vintage Air Gen IV, American Auto Wire Update Series, Champion 4 Core Rad, BMR front w/ Koni's, BP Roller 383, Posi 8.2", Solid Frame Bushings
rtchaney is offline
post #2 of 5 (permalink) Old May 10th, 18, 01:39 PM
Re: Confused electronics.
Bad ground most likely. Check where the lights up front ground to the core support.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 5 (permalink) Old May 10th, 18, 02:28 PM
Larry
Exactly. But to clarify, check the left parking light ground. The housing is gounded via its mounting screws. Or the lamp socket itself might be isolated from the housing from corrosion. Same effect.
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #4 of 5 (permalink) Old May 10th, 18, 04:35 PM
Sean
67-68?
If your saying itís just the indicator in the gauge cluster itís most likely the cluster ground. Itís under the center upper screw that holds the cluster in. There is either a wire or flat metal strap that runs up and under that screw and grounds to the metal dash. Notorious point of gauge ground issues.
If itís at the lamp, probably the ground at the lamp.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 5 (permalink) Old May 11th, 18, 11:59 AM Thread Starter
Robert
rtchaney's Avatar
Rock on. I'll check the indicator ground up front and see what's going on. Here's hoping it's an easy fix!!
- Rob
rtchaney is offline
