Wiring Harness grade - Team Camaro Tech
 9Likes
post #1 of 24 (permalink) Old Jun 14th, 18, 08:46 AM Thread Starter
Kevin
Hi folks, I plan on painting (After13years) my car in about a month. I'm trying to get all my ducks in a row so I'm not sitting around waiting for stuff when re-assembly comes around. I need to upgrade my harness. I have a 67 small block 350/4speed with HEI. No other upgrades. Now for the electrically illiterate, what is the easiest aftermarket harness to install? any tips and or advise would be great.
TIA
kmarron is offline
post #2 of 24 (permalink) Old Jun 14th, 18, 08:49 AM
Steven
stamatisg1977's Avatar
American autowire
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 24 (permalink) Old Jun 14th, 18, 08:52 AM
Mike_M's Avatar
Send a message via MSN to Mike_M
Re: Wiring Harness grade
I have the American Autowire Classic Update harness, I was quite impressed with it. Pretty complete, and all the wires are printed with their function. Modern blade style fuse block, which is nice.
https://www.americanautowire.com/sho...1967-68-camaro
Mike...
Mike_M is offline
post #4 of 24 (permalink) Old Jun 14th, 18, 09:08 AM
For a stock car I would not do a classic update. I would install the stock replacement harnesses from AAW. It is just plug and play aside from a small change for your HEI. Much less effort and less hassle for the electrically illiterate.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #5 of 24 (permalink) Old Jun 14th, 18, 09:42 AM Thread Starter
Kevin
I didn't see a stock replacement on AAW website. Only the Classic Update.
kmarron is offline
post #6 of 24 (permalink) Old Jun 14th, 18, 10:24 AM
They are listed here. It takes several harnesses to completely rewire the stock configuration.
https://www.americanautowire.com/sho...ARO&action=add
dhutton is offline
post #7 of 24 (permalink) Old Jun 14th, 18, 10:34 AM
Pat
ssrocket67's Avatar
Look up factory fit on their website, as far as I can see there is no complete factory fit, just individual harnesses.
1967 Camaro: True RS, Tribute SS, 350 290 HP, Muncie M20 4 SP, 12 Bolt Posi
ssrocket67 is offline
post #8 of 24 (permalink) Old Jun 14th, 18, 10:36 AM
Vega$69's Avatar
The original style is easier to install as you donít need to install all the connectors. The classic is better if you want to add things like power windows.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 24 (permalink) Old Jun 14th, 18, 01:30 PM
keith
X-77 keith's Avatar
Yes there is not one original kit. It has to be pieced together like the factory. That said you can get the original harness upgraded for a HEI and newer altinator if you desire. True plug and play .
X-77 keith
X-77 keith is offline
post #10 of 24 (permalink) Old Jun 14th, 18, 02:40 PM
Don is right about not using the classic upgrade for stock. It does not have a 67 fuse block.
3d cad is offline
post #11 of 24 (permalink) Old Jun 14th, 18, 04:28 PM
Beth
From the reviews I read the classic update isn't hard to install. And the people weren't "electricians" LOL
I bought one for a 67 Chevelle but haven't installed it yet so I can't endorse it.
I like that it uses modern fuses. Does the stock replacement harness still use round glass fuses?
NashvilleCat is offline
post #12 of 24 (permalink) Old Jun 14th, 18, 05:08 PM
Thatís right it is not difficult but the OP says he is electrically illiterate in which case the factory fit makes more sense. The classic update juice isnít worth the squeeze for a stock car being assembled by someone uncomfortable with wiring.
dhutton is offline
post #13 of 24 (permalink) Old Jun 14th, 18, 05:33 PM
keith
X-77 keith's Avatar
Yes still uses glass round fuses.
X-77 keith
post #14 of 24 (permalink) Old Jun 14th, 18, 05:41 PM
Vega$69's Avatar
X2 A fair amount of cutting and crimping with the Classic Update. I have a good Ratchet Crimper and have installed lots of harnesses and re-wires.
I like doing wiring though so way easy for me.
That said add to the Update cost if you have to buy/rent tools
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #15 of 24 (permalink) Old Jun 15th, 18, 04:50 AM
The tools are pricey but once you have used them and the packard style connectors its kind of a hurdle to get over when you find youself having to use the typical hardware.
3d cad is offline
