Gen light on when key in acc position - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 29th, 18, 10:35 PM Thread Starter
Apprentice
Chris
When I put the key into the accessory position on my 68 camaro the alternator light lights up. Is this normal and if not has anyone had this problem and an easy fix. Thanks
seanymph is offline
post #2 of 6 (permalink) Old Jun 30th, 18, 03:31 AM
Kevin
Re: Gen light on when key in acc position
If you mean when you turn the key to first position (not engaging the starter), then yes, this is normal. This is how it works on my 67.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #3 of 6 (permalink) Old Jun 30th, 18, 04:11 AM Thread Starter
Apprentice
Chris
No when the key is turned to the on position before engaging the starter both the gen and oil pressure lights come on. Its when the key is turned counter clockwise to the Accessory position that just the gen light comes on.
seanymph is offline
post #4 of 6 (permalink) Old Jun 30th, 18, 05:07 AM
keith
X-77 keith's Avatar
Any position the key is in without the car running , the light should be on.
X-77 keith
X-77 keith is offline
post #5 of 6 (permalink) Old Jun 30th, 18, 06:24 AM
69-Pace's Avatar
Red face Re: Gen light on when key in acc position
x-2
Saturday morning edition of "more than you wanted to know":
It is the design of the Voltage Regulator/Generator/Energizer "power triad" GM used for decades to power vehicles of all sizes.
In vehicles equipped with GEN warning lights, the bulb turns on in all key positions for a second as a self-test, to tell the operator that the bulb works.
Then a second later it goes on duty in its official job.
In your case in the ACC position, but same is true also in the ON (and in the Run mode once started) key position, it let's you know that the battery (aka the Energizer) is discharging faster than the Generator (aka Alternator) can keep up with the calls from the VR (voltage regulator) to charge the battery.
Once the vehicle is running unless the triad brain the VR says there is an issue in the charging loop you normally won't see the GEN light again until you shut down as it briefly flickers on as you move the key from Run/On position to the Off position and remove the key.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Jun 30th, 18, 02:38 PM Thread Starter
Apprentice
Chris
Thanks everyone for your wisdom.
seanymph is offline
