console wiring - Team Camaro Tech
 1Likes
  • 1 Post By 69-Pace
post #1 of 7 (permalink) Old Jun 30th, 18, 11:45 AM Thread Starter
Big daddy
console wiring
have a 67 that iam changing to 200r4 from 4spd. Also adding console I ordered I ordered wiring for no gages. I want to know where under dash the large connection goes. looks simple,but don't know if cars that were not auto have a connection for new harness to go.
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 7 (permalink) Old Jun 30th, 18, 05:13 PM
69-Pace's Avatar
Re: console wiring
There are actually two harnesses you have to get to add gauges to a factory warning light vehicle. You can make your own and buy all the other parts.
First harness is the so called "Conversion" harness that creates the service stub under the dash to which the actual "console" harness attaches to.
The Console harness is matched to your transmission option - Automatic or Manual and powers and illuminates the gauges. 68 and 89 use the same saw-toothed gauge pack. Only 67 used the tri faced gauges.
The Conversion harness usually comes with a gauge "sender" to replace the temperature "switch" in the block that triggers the warning light.
The Oil switch is replaced with a gauge oil fitting and line. The old oil warning light is relighted and re decal as the low FUEL light.
The GEN warning light is replaced by the battery gauge.
Some companies sell the conversion as a kit with everything you need behind and under the hood. Most do not include the gauges and the 67/68 FUEL instrument decal.
130fe likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 7 (permalink) Old Jul 1st, 18, 07:04 AM Thread Starter
Big daddy
Re: console wiring
my car has no console gages, the harness I got is just for console lighting and n/s switch to shifter,but has plug that looks to connect under dash. where does it plug in?
carhodge is offline
post #4 of 7 (permalink) Old Jul 1st, 18, 07:50 AM
Jeff
yellow69RS's Avatar
Re: console wiring
On a 69 the under dash harness is different if the car has a console or not. The standard wiring doesn't have a place to plug in the console harness, It wouldn't be that difficult to extend the necessary wires to the console harness if originality was not a concern. IIRC with out gages you have NNS(2 purple wires), the b/u lights (2
green wires) and dash lights (1 gray wire).
Jeff
yellow69RS is online now
post #5 of 7 (permalink) Old Jul 1st, 18, 08:00 AM
69-Pace's Avatar
Arrow Re: console wiring
my car has no console gauges, the harness I got is just for console lighting and n/s switch to shifter,but has plug that looks to connect under dash. where does it plug in?
Yes that's the console harness. You now need to buy or fabricate the "Conversion" harness I mentioned in my post above. The conversion harness creates the "service stub" connection that the harness you have connects to under the dash by the radio.
There are a few threads here on Team Camaro referencing adding console gauges for both 67 and 68/69 style gauges or aftermarket equivalents. Personally I buy the conversion harness already made and in the kit form that gives you the sender, oil fitting and all the instructions since you have to go through the bulkhead connector on the firewall. But plenty of electrical engineer minded folks have made their own and got the job done.
Here are a few 67 specific threads to look at:
https://www.camaros.net/forums/gtsea...20installation
69-Pace is offline
post #6 of 7 (permalink) Old Jul 1st, 18, 11:12 AM
Chris
130fe's Avatar
Post Re: console wiring
Like Brian says, if you are not going to be having gauges, I would just make my own conversion harness. Just integrate them into the factory harness, pretty easy to do. The harness that they sell to "add" a console to a non factory harness works well but you can save your self some time and money by doing it your self.
Use 18 awg pink and green for backup lights
Use 10 (or 12, cant remember) AWG purple and purple with with stripe for the NSS switch
and add 18 AWG for lighting (if you are going to have it).
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #7 of 7 (permalink) Old Jul 1st, 18, 11:38 AM
69-Pace's Avatar
Re: console wiring
Yes - Just to clarify you can purchase just a console conversion harness, no gauges, just console for both automatics and manual transmission from the usual places but it is rare. AAW and Lectric Limited make them. Ricks and Classic have them.
69-Pace is offline
