Flasher Not Working w/AAW Classic Update Kit - Team Camaro Tech
 1Likes
  • 1 Post By Chevy68
post #1 of 10 (permalink) Old Jul 4th, 18, 04:28 PM Thread Starter
Trace
I have a 67 with an American Autowire Classic Update kit and a professionally rebuilt GM tilt column. Everything works perfectly except the hazards. I push in the knob, and nothing happens. Anyone have this issue?
'67 LS1 resto-mod
tracetrimble is offline
post #2 of 10 (permalink) Old Jul 4th, 18, 04:30 PM
69-Pace's Avatar
Re: Flasher Not Working w/AAW Classic Update Kit
Is the flasher unit installed?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 10 (permalink) Old Jul 4th, 18, 05:22 PM Thread Starter
Trace
Does it need a second flasher module in addition to the turn signal unit to work the hazards? There was only 1 spot in the fuse panel, but I found it odd that the kit came with 2 flasher modules. I didn't notice this in the schematics, but I'm terrible about reading instructions. I still have all the remnants of the kit to work with.
'67 LS1 resto-mod
post #4 of 10 (permalink) Old Jul 4th, 18, 06:01 PM
Larry
Two flashers needed. One on the fuse panel and the other plugs onto a couple of wires hanging under the dash. Should not be too difficult to identify.
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #5 of 10 (permalink) Old Jul 4th, 18, 06:20 PM
jerry
Try looking in the area by the radio, there is one there on my 69, I never had my 67 dash apart, This link is to a firebird forum, but likely the same for camaro
https://firstgenfirebird.org/forums/...&Number=201940
jerry67 is offline
post #6 of 10 (permalink) Old Jul 4th, 18, 06:55 PM
69-Pace's Avatar
Yes factory harnesses used a second unit under the dash that was mounted at the factory to the radio support bracket toward the lighter and ashtray. I'm not sure how the AAW classic conversion harness sets up. All I have ever seen is the instructions where it is wired with the dash harness and instruction on how to convert if you have a newer than 67-69 steering column connector aka the harmonica. If that doesn't solve your question give them a call first thing Thursday morning. Their phone support is top notch.
69-Pace is offline
post #7 of 10 (permalink) Old Jul 4th, 18, 08:48 PM
Jeff
Yes two flashers are required. They plug directly into the AAW Classic Update fuse panel. They are installed diagonally from each other in the corners on the fuse panel.
130fe likes this.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #8 of 10 (permalink) Old Jul 5th, 18, 07:52 AM
Darin
ilikeike's Avatar
That's how mine is.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 10 (permalink) Old Jul 5th, 18, 04:39 PM Thread Starter
Trace
That was it! The other spot on the fuse panel doesn't have a round feature around it. I also went back through the AAW schematics and couldn't find any reference to it. But, I stuck the other flasher module into it, and they work like a charm now. I'm curious how you guys figured that out, and happy to have working hazards now. Thank you!!
'67 LS1 resto-mod
post #10 of 10 (permalink) Old Jul 5th, 18, 06:13 PM
Jeff
IIRC, I had to trace the wires from the turn signal switch back to the fuse panel on the AAW schematic for the locations.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
