Battery disconnect switch help - Team Camaro Tech
 8Likes
post #1 of 20 (permalink) Old Jul 4th, 18, 11:12 PM Thread Starter
Tim
Hi
I been reading about and have decide that a batt cut off switch is something I would like to incorporate
into my car. I have searched the forum but keep getting threads about moving the battery to the trunk and what not.
I have attached a pic of one I think is somewhat non-invasive,,,anyone know about this type? or have any recommendations?
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 20 (permalink) Old Jul 5th, 18, 03:56 AM
kevin
Re: Battery disconnect switch help
I have seen those along with the knife switch.
I just never understood the need for one unless you have battery draining problem or being on a race track.
car companies don't install them on new cars
flat tire is online now
post #3 of 20 (permalink) Old Jul 5th, 18, 04:13 AM
I think you can make a decent case for them in any of our cars with original wiring. Are the ones like Tim showed built well enough to not just become another problem point?
Niblet likes this.
3d cad is offline
post #4 of 20 (permalink) Old Jul 5th, 18, 04:17 AM
Vega$69's Avatar
The one Tim shows works very well and is not expensive.
Niblet likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 20 (permalink) Old Jul 5th, 18, 04:36 AM
Ray
Have one on my car. Never a problem, very easy to use, and inexpensive.
'68 rs/SS 350 M-21 posi
numbers matching
rgwiz is offline
post #6 of 20 (permalink) Old Jul 5th, 18, 05:09 AM
69-Pace's Avatar
These devices have been around for a very long time and can be found at all auto parts stores at a reasonable price. There are variants such as the mentioned knife style, or the style in your photo where you turn the ring to connect/disconnect.
The reason you see so many threads in a search here at TC related to battery relocation is because many racing organizations and track rules require a cut-off if and or the battery has been relocated for safety or for weight distribution balancing. However these types of interruption switches were oh-so-common in the 70's and 80's, often being a barrel style lock cylinder that folks drilled holes in fenders to mount and possibly displayed with pride.
There are also more modern units that have remote key-fob style disconnect switches, and or have a starter limiting switch that prevent an engine start but leave the other electronics usable. Most of these modern offerings are covert and mount directly to the battery post. I myself use one called the Battery Programmable Brain. Once sold under the brand and marketing name of just "Battery Brain" but the original inventor did not like the course the company he sold the rights to was headed and eventually bought the rights back and re-branded the device BPB. The device comes in remote and wired cut off options and they also offer a device that monitor any hungry electronics such as power amps and radios and can shut them off if the battery gets too low.
My take is that with any of these switches it is best practice to interrupt the POS + leg of the battery circuit as opposed to the installation example in the photo you posted where the NEG - leg is interrupted. I just think it is far too easy to make a body connection to NEG if you have disconnected to work in the engine bay close to the battery area.
There are also alarm system and vehicle locator services such as lojack classic that can kill a battery remotely, some use phone apps as well as fobs.
Battery Programmable Brain is available at Amazon, Summit Racing, many national Auto Parts stores, and direct on-line at: https://www.batterypb.com/product
LoJack Classic - TC members used to get a discount: https://www.lojack.com/products/stol...very-classics/
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 20 (permalink) Old Jul 5th, 18, 05:47 AM Thread Starter
Tim
Thanks for the info Brian!
69-Pace likes this.
Niblet is offline
post #8 of 20 (permalink) Old Jul 5th, 18, 07:37 AM
Darin
ilikeike's Avatar
Almost anytime you work on a car (welding, electrical additions alterations etc..)Long term storage… the factory manual old car or new, recommends disconnecting the battery.
Turning a disconnect switch makes that easy.
rgwiz likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 20 (permalink) Old Jul 5th, 18, 08:10 AM
Beth
This looks like the one in Tim's pic :
https://www.summitracing.com/parts/oes-25281/overview/
I think I'll get one.
NashvilleCat is offline
post #10 of 20 (permalink) Old Jul 5th, 18, 08:15 AM
Ray
Mine is installed on the positive (+) side. Yes it's much easier to give it a full turn to the left instead of disconnecting the terminal when you need to do some work.
Niblet likes this.
numbers matching
rgwiz is offline
post #11 of 20 (permalink) Old Jul 5th, 18, 10:55 AM Thread Starter
Tim
Thanks for the link! The Chevelle needs one too
Niblet is offline
post #12 of 20 (permalink) Old Jul 5th, 18, 11:33 AM
keith
X-77 keith's Avatar
I have seen them at car shows. They are accepted even during points based judging. When a car is judged they want the hood, trunk, and drivers door opened. All three of these parts may or may not have a light hooked to them. This helps insure you don't have a dead battery at the end of the show. I don't have one, but it is definitely easier to turn a knob than remove a factory spring battery cable.
X-77 keith
X-77 keith is offline
post #13 of 20 (permalink) Old Jul 5th, 18, 12:29 PM
kevin
a 1/2" wrench is easy
as a said if it were really important GM would have installed them then and now
personally I have no need for one
post #14 of 20 (permalink) Old Jul 5th, 18, 12:41 PM
Ed
bertfam's Avatar
I have the Battery Brain on ALL my classics. Cheap insurance against 50-60 year old wiring.
Ed
69-Pace likes this.
Ed B. (but you can call me Bert!)
CRG -
bertfam is offline
post #15 of 20 (permalink) Old Jul 6th, 18, 02:47 PM
rick
I switched to this one because of problems that I had with the type you are looking at (poor electrical contact after awhile). This one is more substantial and can be mounted in an inconspicuous place.
https://www.wirthco.com/20387.html
1969 Camaro Coupe -Being Restored
1963 Corvette Convertible - Red/Black, LS3, Tremec 5 speed, R&P, 1996 Suspension
1966 Mustang Convertible - 347 w/Holley EFI, AOD, Candy Apple Red/Black
1973 Ford Bronco - To Be Restored
rick69coupe is offline
