1969 Fuel tank sending unit - Team Camaro Tech
 6Likes
  • 1 Post By 69-Pace
  • 1 Post By emdoller
  • 1 Post By akxtreme
  • 1 Post By 69-Pace
post #1 of 15 (permalink) Old Jul 14th, 18, 10:34 PM Thread Starter
Ed
Lots of great info on this website debugging my fuel gage. My gauge is way to the right past full, somewhere around 3:00.
I removed the sending unit wire in the trunk and grounded the harness (wire running to the fuel gage) turned on the ignition and it went to empty. Good sign it’s not the gauge.
I then measured the resistance between the sending unit wire and the harness where it plugs in and got an open... no resistance at.
I haven’t gotten under the car yet but given the results thus far believe it’s:
1) the sending unit wire came off
2) the sending unit ground is off
3) the sending unit is broken
Does this seem right?
Ed
emdoller is offline
post #2 of 15 (permalink) Old Jul 15th, 18, 06:11 AM
69-Pace's Avatar
Re: 1969 Fuel tank sending unit
Yes Ed. Seems you have isolated the issue to the sending unit. A physical inspection of the ground at the rear of the tank strap, passenger strap would be the next point to look at. Us an alligator clamp and clip it to the ground and then clip the other end to a good ground and retest, if you have resistant then clean and reconnect the ground and test again. If you still have resistance you may have fixed the issue. I say may as even if you have resistance, the float of the sender may be stuck or gives faulty readings. Based on how much fuel you really think is in the tank, add or remove to change the resistance readings. If you get difference then you might be okay. If the change is minimal after changing the amount of fuel by at least three gallons or more then you will have to drop the tank and inspect the sender and or refurbish or replace it.
Vega$69 likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 15 (permalink) Old Jul 15th, 18, 08:05 AM Thread Starter
Ed
Thanks Brian and thanks for the great write up. I will get under the car tomorrow and report back.
Ed
69-Pace likes this.
emdoller is offline
post #4 of 15 (permalink) Old Jul 19th, 18, 01:27 PM Thread Starter
Ed
I looked at the ground and it looked ok. To make sure, I removed the wire, sanded it and ran a jumper. No change. Measured the resistance between the sender wire and harness and itís open.
Iím assuming that means itís the sending unit. Anything else I should try before ordering parts?
Ed
emdoller is offline
post #5 of 15 (permalink) Old Jul 19th, 18, 01:39 PM
Robert
I think your best bet is to just order a new sending unit. You can order one for me while your at it.
emdoller likes this.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #6 of 15 (permalink) Old Jul 19th, 18, 03:36 PM
69-Pace's Avatar
No you about covered it, there is the off chance that it is rotted off at the sender and may be able to be reconnected but maybe not and they are cheap.
FAIR WARNING I would bench test the NEW unit by hooking it up and grounding it BEFORE you install it. Some have been known to be duds out the factory door and nothing worse then draining a tank then to have to drain it twice.
When testing don't get hung up if when you move the float up you go way past the 90 ohms that full is it will just read full on the gauge.
69-Pace is offline
post #7 of 15 (permalink) Old Jul 19th, 18, 05:42 PM Thread Starter
Ed
Thanks. Ordered the Ac Delco version given everything Iíve read on some of the repoís. Great idea on bench testing it. Should arrive in a week or so.
Ed
69-Pace likes this.
emdoller is offline
post #8 of 15 (permalink) Old Jul 20th, 18, 07:07 AM
Fred
77thor's Avatar
Ed
Just curious... Who did you order from??
77thor is offline
post #9 of 15 (permalink) Old Jul 21st, 18, 07:47 PM Thread Starter
Ed
Sorry for the delay. I ordered it from classic industries. They are having a 25% off sale.
Ed
emdoller is offline
post #10 of 15 (permalink) Old Jul 26th, 18, 12:16 PM Thread Starter
Ed
Got my new sender. Bench tested it and it worked. To make sure it fixed the problem I hooked it up to the car wiring and turned the key. Nothing happened. I then grounded the wire going to the gauge as this moved the needle last time I tried. It didnít move.
After scratching my head I decided to tap the gauge and that did it.
Put it all back together and itís working although I think the gushed is off about 1/8 of a tank. I can live with that especially because itís 1/8 less than whatís in the tank.
Thanks for the help especially Brian for the debug writeup.
Ed
69-Pace likes this.
emdoller is offline
post #11 of 15 (permalink) Old Jul 26th, 18, 12:23 PM
Dan
I'm helping a friend with a similar issue. First problem is we can't find the plug that connects to the back of the fuel gauge under the dash. Does anyone have a handy picture of this 3-prong connector?
I found the correct color wires going to the body harness connector under the dash and the wiring going to the fuel tank is all there but no sign of that fuel gauge connector and no evidence that it was cut out.... weird.
thegodown is offline
post #12 of 15 (permalink) Old Jul 26th, 18, 05:02 PM Thread Starter
Ed
All I have is the wiring diagram. It shows the wires and a three prong connector. I didnít get under my dash because I determined it was the sending unit by following Brianís guide.
Ed
emdoller is offline
post #13 of 15 (permalink) Old Jul 26th, 18, 05:51 PM
Dan
Thanks Ed.
post #14 of 15 (permalink) Old Jul 26th, 18, 06:31 PM
There is a pigtail connection in the trunk next to the lock structure.
You can troubleshoot from there, as in hooking up another sending unit or 0-100 ohm rheostat and ground to the wire going into the harness, and measure resistance referenced to ground with the wire going through the floor to the tank.
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
post #15 of 15 (permalink) Old Jul 27th, 18, 07:42 AM
Ed
Make sure you buy a quality sending unit if you replace it. Here are some options for you.....
https://www.jegs.com/webapp/wcs/stor...ersistYmm=true
ZEN357 is offline
