67 RS no headlights or tails - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 18th, 18, 05:25 PM Thread Starter
Apprentice
Brent
Be patient with me this is my first Camaro and I didnít grow up with these cars so sometimes have dumb questions. TIA.
67 RS currently no headlights, tail lights or brake lamps. Headlight doors do not open. Turn signals work fine besides passenger front but that is a pre-existing issue prior to this.
Interior lights work fine by door switch so if my door is open both interior lights work. Hazards work as well. Gauges are these Dakota Digital(not a fan) ones and all work fine.
Is there a fuse in the driverís foot well that I need to check? Is there another fuse box I should be looking for?
Once again thank you trying to get a place to start. Worked fine a few days ago.
Sent from my iPhone using Tapatalk
Brent396 is offline
post #2 of 12 (permalink) Old Jul 18th, 18, 06:29 PM
Re: 67 RS no headlights or tails
You will find the fuse box under the driver's side dash. Check there first. The fuses should be marked.
Old Dad's 67 is offline
post #3 of 12 (permalink) Old Jul 18th, 18, 06:45 PM
69-Pace's Avatar
Grounds are terrible in first gens and are 90% of all electrical light gremlins. 67 RS factory headlights use boards and relays. These commonly cause issues with relays and limit switches needing replacement, tweaking etc.
So let us know are the RS headlights original to the car and still using the original boards or did the previous owner install them using newer technology.
Does pressing the bright switch on the floorboard turn the lights on or snap the doors open?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 12 (permalink) Old Jul 18th, 18, 08:44 PM
Roger
rogerh's Avatar
There is just one fuse panel on your car. Could be some inline fuses if anything was added over the last 51 years. The relay board that controls the headlight doors Brian talks about is under the left front fender by the windshield washer reservoir.
Roger
rogerh is offline
post #5 of 12 (permalink) Old Jul 19th, 18, 04:45 AM Thread Starter
Apprentice
Brent
The box looks to be original and the labeling is well worn off. Do you have a print out of picture of which is which.
Also the wiring has been messed with over the years there is no doubt about that.
Would the headlight relays in the engine bay effect the taillamp and brake lamps?
Brent396 is offline
post #6 of 12 (permalink) Old Jul 19th, 18, 07:24 AM
Camarodude67
You probably have a bad headlight switch. I have a lot of pics for 67 RS relays, wiring, etc I can text you...
Jeff G.
Hartford CT
camarodude67 is offline
post #7 of 12 (permalink) Old Jul 19th, 18, 09:25 AM
There is a photo of the fuse box in this link...https://www.camaros.net/forums/19-el...ghts-help.html. When in doubt, grab a test light and check all your fuses. It looks like the bottom fuse is for tail and stop lamps.
On the RS headlight panel under the left front fender, there are 3 relays and a 10 amp circuit breaker. Check the circuit breaker first. All 4 components can be purchased for under $40. Here is info on how to troubleshoot https://retro-electro.net/FAQ67.html. I doubt this circuit panel has anything to do with the rear lights.
As camarodude67 suggested, you may have a bad headlight switch.
post #8 of 12 (permalink) Old Jul 19th, 18, 02:40 PM Thread Starter
Apprentice
Brent
To update he original post. When I pull the headlight lever out to the parking light position the parking light comes on. Headlights do not.
Prior to this headlights came out in the parking lamp position.
So no headlights, brake lights, tail lights, no motorized RS headlight doors either.
Turn signals work as normal, parking lights work as normal, hazards normal, interior courtesy lights on when door is open.
Brent396 is offline
post #9 of 12 (permalink) Old Jul 19th, 18, 06:57 PM Thread Starter
Apprentice
Brent
Removed this from the car. Should a 67 RS have a 7 or 8 PIN headlight switch?
Would the wrong switch account for before (when lights were working) having the headlights come on while the plunger was pulled only to the parking light position?
Brent396 is offline
post #10 of 12 (permalink) Old Jul 19th, 18, 07:31 PM
I checked my old one. It looks just like yours...8-Pin. Here's a link for the photo. https://shop.advanceautoparts.com/p/...415p/5970857-P
post #11 of 12 (permalink) Old Jul 19th, 18, 08:35 PM Thread Starter
Apprentice
Brent
I tested continuity and it checked fine. Also tests the dimmer worked perfectly (moot point since I have Dakota digital gauges)
I am going to pickup a new floor dimmer switch too while I am at the parts store just incase.
I feel a brand new full harness is in order this winter get rid of the 50 year old harness.
Brent396 is offline
post #12 of 12 (permalink) Old Jul 22nd, 18, 02:45 PM Thread Starter
Apprentice
Brent
Bought a test light. Here is a picture of my fuse box. The bottom two glass fuses are good. Third from the bottom is missing. The top four glass tube fuses have no power at all on either side of the fuse.
Turned the key to ON and rechecked. The top three all have power. The 4th one down or up doesnít have any power at all. The empty one has power on the left obviously no fuse to go through. Bottom two checked good again.
I have a new headlight switch shipping as well. Does anyone know what my empty spot does and also what the one that is completely dead does?
Brent396 is offline
