Ground wires on driver side of core support - Team Camaro Tech
 1Likes
  • 1 Post By rogerh
post #1 of 3 (permalink) Old Jul 24th, 18, 06:44 PM Thread Starter
Joe
Put in a new core support for this 68 restoration with new wire harness. My old core support had two ground wires located on the driver side (next to voltage reg.), one from the wire harness and I've got that okay but where does the second one go to? Thank you!
joegs68 is offline
post #2 of 3 (permalink) Old Jul 24th, 18, 07:01 PM
Roger
rogerh's Avatar
Re: Ground wires on driver side of core support
The 68 is a different animal than my 67 but this may help. If the voltage regulator is attached to the radiator support with well-nuts it needs a ground wire. The pictures in this post shows that ground.
https://www.camaros.net/forums/19-el...vr-ground.html
Roger
joegs68 likes this.
rogerh is offline
post #3 of 3 (permalink) Old Jul 24th, 18, 08:21 PM Thread Starter
Joe
I believe you are correct. It's beem a long 6 years since I started this so it was hard to remember. Thank you so much!
joegs68 is offline
