1969 Headlight switch - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 28th, 18, 06:56 PM Thread Starter
Probationer
I have a 69 camaro I replaced headlamp switch head lights work brake and turn signals no parking or tail lights
Marines069 is offline
post #2 of 6 (permalink) Old Jul 28th, 18, 07:19 PM
69-Pace's Avatar
Re: 1969 Headlight switch
Hey Marines069 check your PM inbox.
Brake and turn signals do or don't work? Hard to tell from your statement. Double check your grounds at the parking lamps up front if they don't work.
Did these light that don't work now - work before you swapped out the headlight switch?
Check the headlight harness connector to make sure you have it all the way on the new switch if you haven't already looked there.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old Jul 28th, 18, 07:22 PM
Daryl
1968RallySport's Avatar
Did you buy the correct switch. Thereís a 7-prong and an 8-prong.
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #4 of 6 (permalink) Old Jul 28th, 18, 07:28 PM
keith
X-77 keith's Avatar
Turn signal switch? Don't those go through it?.
X-77 keith
X-77 keith is offline
post #5 of 6 (permalink) Old Jul 29th, 18, 07:29 AM
Jeff
yellow69RS's Avatar
Brake and turn go thru the T/S switch but the parking and tail do not. If there is a 7 and 8 terminal switch that is my first choice for the problem. My second choice is the switch has a terminal in a different spot then the plug on the harness.
Jeff
yellow69RS is offline
post #6 of 6 (permalink) Old Jul 29th, 18, 08:18 AM
Rick
Legacy 69's Avatar
Check grounding to rad support.
Legacy 69
Legacy 69 is online now
