Pertronix II air gap - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 23rd, 18, 08:18 AM Thread Starter
Apprentice
Craig
I'm installing a 91181 Ignitor II into my 1969 Chevy Camaro. I have the distributor out and I'm working on the air gap between the ring and the module. As I rotate the distributor the air gap varies. The ring sits flat on glass. No play in the distributor shaft.
​Should I just get the gap as best as I can on the closest air gap. Or should I look at where the ring mounts and see if I can bend that plate to even the gap?
69 Camaro SS
cef2lion is offline
post #2 of 3 (permalink) Old Aug 23rd, 18, 12:18 PM
kevin
Re: Pertronix II air gap
hang on the pro will be around to answer your ?s
flat tire is offline
post #3 of 3 (permalink) Old Aug 23rd, 18, 12:24 PM Thread Starter
Apprentice
Craig
I sent a message to Pertronix tech support and got this back.
The air gap can be anywhere between 0.005" and 0.070". The gap wont be level all the way around, but it wont matter as long as you are between that range.
69 Camaro SS
cef2lion is offline
