Can I buy a "partial harness"? pls look at the pics - Team Camaro Tech
 1Likes
  • 1 Post By stamatisg1977
post #1 of 6 (permalink) Old Aug 25th, 18, 06:11 PM Thread Starter
Tim
So I removed my starter today and noticed that the small wires
going to the solenoid need attention, so I started following them back and of course one terminates at the coil and the other goes to this plug prior to disappearing into the firewall (its the purple one I believe)
Can I buy just the portion that goes from the plug, along the top of the firewall and down to the starter? I know there are a couple of other wires in that bundle but so be it...
heres a pic, taken from Drivers side hood hinge area
Thanks!
ID:	220995   Click image for larger version
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 6 (permalink) Old Aug 25th, 18, 07:27 PM
69-Pace's Avatar
Re: Can I buy a "partial harness"? pls look at the pics
Try M & H Electric Fabricators Reproduction Wiring Harnesses for America's Muscle Cars
They have a very full catalogue
And also Letcric Limited https://www.lectriclimited.com/repair-components/
One or the other should be able to make up what you need if they don't already have it on the shelf.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old Aug 25th, 18, 07:27 PM
Beth
American Autowire sells an original harness , so I would email them with pics and see what they can do.
From what I remember, the original harness is sold in many pieces so you should be able to buy the part you need.
https://www.americanautowire.com/callemail-us/
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 6 (permalink) Old Aug 25th, 18, 07:34 PM
I would look at the connector real close while it's apart and get an idea how well it's holding up after all of these years. Maybe also take the other one apart to look at it paying attention to the main feed connections from the horn relay buss.
If it's just a wire or two, you can get replacement terminals for the connector, get the proper wire along with some loom tape and repair what you have or you might just be able to buy the engine harness and/or the complete underhood harness.
Another option is go back on the existing wires, splice in a new section of wire, cut it to length and then terminate it.
You just need to closely look at things and make the decision on how to repair or replace things. Photo's online can only show so much but your eyeballs should see things we cannot.
SOA-Nova is online now
post #5 of 6 (permalink) Old Aug 25th, 18, 07:39 PM
Steven
stamatisg1977's Avatar
I may have an extra engine harness brand new. Tomorrow i will take a look
Niblet likes this.
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #6 of 6 (permalink) Old Aug 26th, 18, 01:27 PM Thread Starter
Tim
Thanks for checking on that, yes Im going to dig into it a little more and check the condition of the wires
Niblet is offline
