Original Alternator pictures - Team Camaro Tech
 5Likes
post #1 of 22 (permalink) Old Aug 27th, 18, 07:59 PM Thread Starter
Tim
Heres some pics of the Alternator on my Nov 66 built, 67 SS350
The date code looks like a nov 66 built Alt as well
is that yellow mark an inspection mark of some type?
ID:	221047   Click image for larger version
Name:	ALT Number.jpg
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 22 (permalink) Old Aug 28th, 18, 03:59 AM
kevin
re: Original Alternator pictures
I am guessing someone had it apart and the yellow lines are reference points for reassembly
dyno jonn and Petes L48 like this.
flat tire is offline
post #3 of 22 (permalink) Old Aug 28th, 18, 04:33 AM Thread Starter
Tim
how could you screw that up?
Niblet is offline
post #4 of 22 (permalink) Old Aug 28th, 18, 04:54 AM
Chick
68camaroz28's Avatar
Letter I was not used in some date coding applications and true for alternators. Yours was made month of October. For the yellow line, I've not noted that yellow mark on previous alternators from the factory but it assume it could have been placed there or possibly as Kevin suggested.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #5 of 22 (permalink) Old Aug 28th, 18, 05:50 AM
Michael
Very easy......you can 'clock' the alternator half's wrong when re-assembling it after service and depending on the usage (engine type) it may not mount properly due to the rear section hitting a valve cover.
flat tire likes this.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #6 of 22 (permalink) Old Aug 28th, 18, 07:23 AM
Rob
satz28's Avatar
Simply an observation....the color looks to be very close to the same yellow used to mark the x on the bulkheads....appears to be a wax pencil as it looks like it weeped oily marks around the entire yellow stripe.
Rob
Sold 6-1-2014 after owning the car for 18+ years
69 Z-28 X-77 HO * DZ Put away * M20 * 4.10
406 CI * CC XR274R 236/[email protected] 564/570 110 LSA/106 ICL * Brodix IK 200
475 HP, 495# tor
Street Tires, Full Exhaust Sep 07 -12.68 @ 113 MPH * Street Tires, Open Headers Oct 08 - 12.65 @ 116.2 MPH
satz28 is offline
post #7 of 22 (permalink) Old Aug 28th, 18, 10:16 AM
Roger
rogerh's Avatar
This is a few of the threads on alternator that may be useful. It appears your alternator is a heavy duty 61 amp from 67.
The yellow marking, I am sure is a indication the alternator was rebuilt at one time or the other. I say that because I had my alternator overhauled locally and when I got it back it was clocked 90 degrees off. The alternator hit the valve cover when I tried to install it. If the mark had been there from the factory that wouldn't have happened. I just took it back and he clocked it correctly.
https://www.camaros.net/forums/15-ta...or-decode.html
https://www.camaros.net/forums/15-ta...lternator.html
https://www.camaros.net/forums/15-ta...ternators.html
Roger
rogerh is offline
post #8 of 22 (permalink) Old Aug 28th, 18, 10:20 AM Thread Starter
Tim
that makes more sense as the car was a late Nov build, Thanks!
it also has Factory A/C hence the RPO K76 HD 61 Amp Alternator
Niblet is offline
post #9 of 22 (permalink) Old Aug 28th, 18, 10:30 AM Thread Starter
Tim
i did not know that
Niblet is offline
post #10 of 22 (permalink) Old Aug 28th, 18, 11:40 AM
Russ
Actually the 61 amp would have been part of/included with the RPO C60 four season air conditioning package. That's why you see so few under the K76 in the CRG options spreadsheet. Those are ones ordered outside of the C60 option.
Petes L48 is offline
post #11 of 22 (permalink) Old Aug 28th, 18, 11:46 AM Thread Starter
Tim
Thats what I meant Lol,,thanks for correcting me
Niblet is offline
post #12 of 22 (permalink) Old Aug 28th, 18, 11:50 AM
Chick
Like to add what Rob is stating as I do agree the mark does have the same look as other yellow crayon marks that are found at times. Was the mark to help identify the higher amp alternator for the line??? On our 68Z there was a yellow long crayon mark on our bell housing which I've noted on other survivors and duplicated upon restoration. Why was that there, do not know! Reason I stated earlier it might have come from factory that way or again as Kevin suggested, a rebuild.
Chick
Our 68Z Restoration
post #13 of 22 (permalink) Old Aug 28th, 18, 11:59 AM Thread Starter
Tim
I think its factory, just my opinion, the original owner never mentioned anything about a rebuild on the alt,
and its only got 54K on the clock,,therefore it is my belief its factory,,probably will never know for sure
Niblet is offline
post #14 of 22 (permalink) Old Aug 28th, 18, 12:36 PM
kevin
it's your car you car. believe what you want.
I am just saying that my 68 that I bought in 72 never had any markings anywhere and I talked to the original and second owner, and asked many ????
post #15 of 22 (permalink) Old Aug 28th, 18, 12:53 PM Thread Starter
Tim
And you can believe what you want, I spoke with the original owner at length, he never mentioned a rebuild, but its really insignificant
Niblet is offline
