Headlight question NO Low beam but HI - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 28th, 18, 05:46 PM Thread Starter
JC
Send a message via AIM to JC69RSZ28
69 RS have high beam no low, ? new dimmer switch new headlight switch? is it a simple as a ground wire? or when I put the car back together did I forget something?
1969 Hugger
JC69RSZ28 is offline
post #2 of 5 (permalink) Old Aug 28th, 18, 06:03 PM
Chick
68camaroz28's Avatar
Re: Headlight question NO Low beam but HI
JC, quite common for the low beam headlight to be burned out yet the high beam works. That is probably or quite possibly what your issue is.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #3 of 5 (permalink) Old Aug 28th, 18, 06:23 PM Thread Starter
JC
Ok. I guess very possible.. both low beams? I think I have a spare light around here I will check. Thanks
1969 Hugger
post #4 of 5 (permalink) Old Aug 28th, 18, 06:42 PM
Vega$69's Avatar
Pull the headlight and put 12v bat to it with a ground jumper to test.
And/or pull the 3 prong off the bulb and check for 12V with a multi meter between the low beam term and a good grond.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 5 (permalink) Old Aug 28th, 18, 08:22 PM
69-Pace's Avatar
Or use the continuity test mode on your multi-meter if it has one, it will fail if the low beam filament is broken.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
