Door jamb switch wiring - Team Camaro Tech
 1Likes
  • 1 Post By 327fuelinjected
post #1 of 4 (permalink) Old Sep 5th, 18, 01:58 PM Thread Starter
What is the correct routing for the passenger side door jamb switch wire on a 67 ? under the rear deck, across the roof and down behind the sail panel or across the floor?
67 RS/SS 350, M21, 3:70 POSI, Hooker side mount headers, blue dot tail lights. owner since 1974.
327fuelinjected is offline
post #2 of 4 (permalink) Old Sep 5th, 18, 03:35 PM
Re: Door jamb switch wiring
I just disassembled a 68 and it ran across the inside of the dash. There was small "clips" attached to the dash that the wire ran through. My 69 is similar (runs across the dash). My guess is that 67 sould be about the same. The wiring from the overhead light runs across the roof and down to the floor by the sail panel, which is all part of the in harness in the car that runs along the driver side floor and up the kick panel. Hope I didn't confuse you with all that jumbo.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #3 of 4 (permalink) Old Sep 5th, 18, 04:01 PM
My 67 has clips in the gaps directly under the dash pad.
3d cad is offline
post #4 of 4 (permalink) Old Sep 6th, 18, 04:56 AM Thread Starter
Thanks, I don't even know why I posted this, I was actually thinking about a 67 caddy not my Camaro. I'm old.
pwentz3l likes this.
