No power - Team Camaro Tech
 1Likes
  • 1 Post By BRICO69
post #1 of 8 (permalink) Old Sep 8th, 18, 09:53 PM Thread Starter
Probationer
No power
I just bought a 85 and it came with a 350 that it looks like the guys project car....it needed a new stater sparkplugs and battery to start i did all that and i went to start it and it scratched so i shemed the starter and went to try again and no power WHAT SO EVER i check all the grounds they all checked out good batter is good alternator good starter still good but no power no lights nothing just dead can anybody help me out please?
Marohead214 is offline
post #2 of 8 (permalink) Old Sep 9th, 18, 05:15 AM
69-Pace's Avatar
Re: No power
Well I would start with the basics, trace from the starter back to battery if it was starting before you shimmed the starter then nothing. The issue has to be between battery and starter or wiring at starter.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 8 (permalink) Old Sep 9th, 18, 05:55 AM
Re: No power
Could be missing the power lead from starter BATT stud to the rest of the circuits.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
post #4 of 8 (permalink) Old Sep 9th, 18, 07:36 AM Thread Starter
Probationer
I checked the grounds from the battery to the starter and everything was ok but still nothing.....i even tried to jumping it and still nothing
post #5 of 8 (permalink) Old Sep 9th, 18, 01:14 PM
Re: No power
Does it have a fuseable link? Maybe check out thirdgen.org. They might be able to help.
wireboy355 likes this.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #6 of 8 (permalink) Old Sep 11th, 18, 06:43 AM Thread Starter
Probationer
No gas
So i fixed the power problem .......now im getting no gas to my block to start lol i think im out ive never started the car im going to go try later today i put a new fuel pump on too
post #7 of 8 (permalink) Old Sep 11th, 18, 07:15 AM
Re: No power
Good deal. What was the power problem?
you might disconnect the inlet to rail fuel and apply low pressure shop air to tank, use nozzle and rag to seal, yes, not good, but will work, and pressurized tank priming fuel pump and line.
Or, jumper across f/pump relay socket and have pump prime fuel.
You will know when pump is pumping, high pitched whine to a growl, typically 5-6 amps current under load, if measuring.
post #8 of 8 (permalink) Old Sep 12th, 18, 07:25 AM Thread Starter
Probationer
The wires to the starter was wrong. The gas problem is just very stupid right now i found lines coming from gas tank that wasnt connected at all i reconnected them but one line still hangs and idk where to connect it with
