Installing kick panel speakers - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 9th, 18, 04:05 AM Thread Starter
Ken
Anyone installed Pioneer speakers in kick panels? I can't figure out how to attach the plastic surround. The instructions show it being used with the little bolts, nuts and washers provided but they aren't long enough to even go through the surround. I assume these mount flush to the outside of the kick panel. If so do those repro 4x6 grills cover them? They will be about 3/8 inch raised above the surface of the kick panel and all the pics I see of those grills don't look like they are that thick.
Name:	Pioneer speaker 2.jpg
Winch is offline
post #2 of 6 (permalink) Old Sep 9th, 18, 06:33 AM
Kevin
KevinW's Avatar
Re: Installing kick panel speakers
Ken, I used speed nuts from home depot, slide them on to the kickpanel itself. You can see one of the silver speed nuts peeking out on the upper right of the speaker frame.
I then used a long oval head screw in the factory style grill to go through the speaker frame into the speed nuts. You can see the screws and grill lower left on this pic.
I used the Kappa 2-way 4x6" speakers in my kick panels.
Kevin
KevinW is online now
post #3 of 6 (permalink) Old Sep 9th, 18, 08:13 AM Thread Starter
Ken
Did your Kappa speakers come with the covers (grills)?
Winch is offline
post #4 of 6 (permalink) Old Sep 9th, 18, 01:18 PM
Kevin
KevinW's Avatar
I think they did come with something, but the ones in the pics are the repro 69 Camaro factory ones I got at Ricks.
Kevin
post #5 of 6 (permalink) Old Sep 9th, 18, 06:52 PM
Bruce
The attaching screws will pull the kick panel tight to the grill.
The Camaro Guy is offline
post #6 of 6 (permalink) Old Sep 9th, 18, 08:41 PM
Larry
I used the grills that came with my speakers. It does extend out from the panel quite a bit and still does not interfere with the E-brake.
I also used the speed nuts on the panel to hold everything together. Worked quite well.
Here's my example:
DSC_1739 by Larry Madsen, on Flickr
DSC_1735 by Larry Madsen, on Flickr
I can't complain, but sometimes I still do.
Larry Madsen is offline
