Autometer Electric Speedo with Tremec T-56 Mag - issues with sender - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 27th, 18, 07:24 AM Thread Starter
Greg
pittpens24's Avatar
Speedo would not work so naturally I called Autometer. They said I should have atleast 2 volts measured with an Ohm meter on DC that will gradually increase as the rear tire is spun faster(by hand). My original sender was dead - did nothing. Bought a new one and that one worked as I would told it would with more volts as the tire spun faster. Hooked everything up and went to program my speedo and nothing. Called Autometer and they said to send the gauge back and they would fix it. Upon taking the dash apart, I figured I would double check the voltage at the back of the gauge - nothing. Figured it was the wire so I checked again at the sender and nothing - it is dead. Thoughts??? I am stumped
Wired as such from Autometer tech:
Yellow wire to chassis ground
Purple wire to Speedo input
No ecu so only need a 2 wire.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #2 of 2 (permalink) Old Oct 1st, 18, 04:16 AM Thread Starter
Greg
pittpens24's Avatar
Re: Autometer Electric Speedo with Tremec T-56 Mag - issues with sende
Finally figured it out. The 2nd sender had a weak pin connector, I had nothing because the wire lost contact. I bought a 3rd from Ford for good measure just in case. Turns out there is a simple way to test these as per Bob Hanlon at Hanlon Motorsports. Put your OHM meter on the lowest setting on dc volts with +/- on the pin connectors and run a screwdriver(or something metal) across the pick up. If you are reading volts, you are good. Turns out my original sender was good which leads me to wiring and a continuity test. Turns out that the harness I bought must have had a broken wire from the factory or possibly pinched somewhere(which is nearly impossible because the harness is wrapped from the trans to just in side of the firewall). Luckily the harness had a yellow(ground) and purple(feed) wire in it running the course. The yellow wire passed the test so I grounded the one of the wires to the crossmember, and used the yellow ground wire as my feed wire - voila!
Moser 9" with 4:11
572 BB - CM Engines
