Horn help - Team Camaro Tech
 1Likes
  • 1 Post By bondora68
post #1 of 15 (permalink) Old Oct 1st, 18, 05:48 PM Thread Starter
Tony
Horn help
I’m completing my restoration on my 68 convertible. I used a new wiring harness from American Auto Wire. I have an original deluxe SS steering wheel. My horn does not work. Here’s a pic of the steering wheel. Anyone know the correct wiring?
ID:	221917   Click image for larger version
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 15 (permalink) Old Oct 2nd, 18, 04:30 AM
69-Pace's Avatar
Re: Horn help
Tony - I moved this thread to the Electrical section of the forums.
Did you install the AAW update kit or the classic factory fit line?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 15 (permalink) Old Oct 2nd, 18, 05:31 AM
Vega$69's Avatar
Re: Horn help
The AAW update does not I use the OEM horn relay. It uses the AAW supplied horn relay that plugs into the harness under the dash.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 15 (permalink) Old Oct 2nd, 18, 07:05 AM Thread Starter
Tony
Re: Horn help
Yes, I used the supplied horn relay from AAW which plugged in under the dash. I don't know if I wired the steering wheel correctly...
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #5 of 15 (permalink) Old Oct 2nd, 18, 07:20 AM
Vega$69's Avatar
Re: Horn help
Can you hear the relay click when you push the horn button?
Vega$69 is offline
post #6 of 15 (permalink) Old Oct 2nd, 18, 09:07 AM
Jake
697ibew's Avatar
Re: Horn help
Tony...i am having the same issue that you are. I have a 68 Vert and AAW Update Wiring as well. The only difference is that my horns used to work before paint. I just haven't had time to investigate it.
Don't hold me to this but i believe the coil of the relay is energized (thus closing the tips of the relay) by pushing the horn button and completing negative side of the coil circuit. Like i said, i haven't had to time to verify this and troubleshoot it yet. Good luck Tony!
697ibew is offline
post #7 of 15 (permalink) Old Oct 2nd, 18, 09:55 AM
Vega$69's Avatar
Re: Horn help
Jake. Your horns are most likely not grounded well due to the paint.
Yes horn button closes relay and puts 12v to the horn.
Simple horn test is put battery jumper to the 12v tab on the horn. Honks ok then grounds are good and problem is somewhere else. No honk and it either bad ground or bad horn.
Vega$69 is offline
post #8 of 15 (permalink) Old Oct 2nd, 18, 10:52 AM Thread Starter
Tony
Re: Horn help
No, I cannot hear the relay clicking..
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #9 of 15 (permalink) Old Oct 3rd, 18, 05:00 AM
Kevin
Re: Horn help
I too suspect that the horn brackets are not getting a good ground, due to the new paint.
To test the horns past the relay, do as Vega$69 mentions in post #7. If the horns work, the horns are grounded good, and the issue will be with the ground wiring from the steering wheel to the relay, or the relay itself. To test the relay, make a temporary ground from a piece of wire; ground one end of the wire to a body location in the engine compartment. Using the other end of this wire, touch the ground post of the relay (this post would get ground when the horn button is pressed). If the horns work, then the relay is good, and the wire from the ground side of the relay point to the steering wheel horn button is the culprit.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #10 of 15 (permalink) Old Oct 4th, 18, 01:02 PM
Re: Horn help
Did you take the steering wheel apart at all?
If so, take steering wheel cover off again and make sure the spring, connecting the horn button wires, to the metal tab down in the steering wheel is there.
If it's not...take apart a ball-point pen, take the spring from it, stretch it slightly, drop it in the barrel, put steering wheel cover horn wire 'plug" in place, put steering wheel cover back on, and honk your horns. Ask me how I know this...
If the spring IS in there... has to be in the wiring setup.
'68 Convertible, #'s Matching, 327/210HP
LeMans Blue - Deluxe Parchment Interior
Power Steering, Powerglide, 10-Bolt, 2.73:1
Norwood car, Build date 03D
'53 Ford Crestline - Hardtop
Raven Black/Sungate Ivory
239 Flathead V-8
53Crestline is offline
post #11 of 15 (permalink) Old Oct 23rd, 18, 08:59 AM Thread Starter
Tony
Re: Horn help
OK, I tested my original horns at the battery and got nothing. I ordered 2 new reproduction horns and tested them at the battery. They worked fine. They came with new brackets so I mounted them RS style behind the grille and ran a jumper from the battery to the horns and they worked fine. I plugged them into the wiring harness and then turned my attention to the steering column. I took off the steering wheel shroud and testing the horn contacts there and got nothing. I got a small flat file and filed the connection contacts on both sides. When I hooked everything up correctly with the spring and wire that branches out to the wheel contact points I got nothing. When I grounded a wire to the steering wheel center bolt and touched it into the hole with the spring the horns blew depending on how far I stuck the wire into the spring. So, I put a pin inside the spring and wrapped the wire around the pin and wedged it into the hole. When I grounded this wire it blew the horn. So I created a ground point at the center of the wheel by welding 2 wires on to a washer that fit behind the nut that holds the steering wheel on. The wires went out to the horn contacts on the left and right sides to provide a better contact point for the horn ground. I tucked all that behind the shroud and screwed it all back together. It works great now!
697ibew likes this.
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #12 of 15 (permalink) Old Oct 23rd, 18, 10:50 AM
Vega$69's Avatar
Re: Horn help
Did you not have the contact pan that assembles with the spring into the signal canceling ring
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 15 (permalink) Old Oct 23rd, 18, 07:23 PM Thread Starter
Tony
Re: Horn help
[QUOTE=Vega$69;1783096845]Did you not have the contact pan that assembles with the spring into the sign
I had what was left of the old one that was not making contact. I could not find another one...
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #14 of 15 (permalink) Old Oct 24th, 18, 07:51 AM
Re: Horn help
Tony, This is the pin you need (or needed).
67 68 69 70 71 72 73 74 Camaro Horn Contact Spring & Pin Set - 1967, 1968, 1969 Camaro Parts - NOS, Rare, Reproduction Camaro Parts for your Restoration
my 67' build thread:
allanjs is offline
post #15 of 15 (permalink) Old Oct 25th, 18, 09:37 AM
Re: Horn help
Note that not all require the Pin. Some, just the spring. As in my case.
239 Flathead V-8
