67 Headlights will not turn off - Team Camaro Tech
post #1 of 1 (permalink) Old Oct 14th, 18, 04:39 PM Thread Starter
Probationer
First time on the forum, looks like a great place for information.
I just recently replaced my under dash harness and put in a new diode harness on my 1967 RS. I also put in a new light switch. Here are the symptoms of my problem:
- Headlights come on automatically (doors remain closed) when I hook up the battery and they will not turn off.
- RS doors will not open or close with the light switch, but will work correctly when you press the little switch on the assembly.
- Even if I completely remove the light switch, there is no change.
- Taillights turn on and off with the light switch correctly.
I double checked all the wiring and still cannot figure anything out.
Any ideas?
Thank you!
jonesmi1 is offline
