Mini Starter Installation help, This is why I dont like to modify stuf - Team Camaro Tech
 30Likes
post #1 of 74 (permalink) Old Oct 28th, 18, 07:56 AM Thread Starter
Tim
So taking the advice of some here on the forum, I decided to install a mini starter on my 67 RS when the solenoid on the OEM starter went bad.
I ordered one from Amazon, a "Tuff Stuff" product, and proceeded with the install according to the supplied instructions.
I bolted it on right out of the box and took a look at where the pinion gear to flywheel was and decided it needed more shims. I used the one supplied with the kit, (I noticed it already had a set of shims installed so now I have 2 shims under the starter mounting block. I also ended up with 1 shim on the engine block to obtain my pinion backlash of .040 +/- .015
I have 2 questions:
1. it looks like I still need more pinion to ring gear clearance, so I will need to order and install another set of shims under the starter block,,is 3 sets of shims uncommon?
2. I look at the wiring instuctions and its telling me I need to order a remote solenoid or a relay because I am still running a points ignition,,,gee,, it would have been nice to know this before I ordered the starter in the first place,,,
This is why I destest modifying anything from stock,,.,there is always some rig-a-ma-roll involved with making something that was not originally on the car work,,,like adding a relay or a remote solenoid,,,WTF?
also I am installing a new engine wiring harness as well and now I have to cut into it to splice in this F'in relay they are talkin about? the instructions for the additional remote solenoid only state that it adds more juice to the starter for hot starting issues,,says nothing about needing it because of breaker points,,reckon I will call the tech line tomorrow
the pics below show the relation to the pinion/flywheel clearance ( or lack thereof) before I installed the supplied shim,,its not much better now,, that's why I think I need one more, the other pics show the installation of the supplied shim set,,again, is 3 shim sets unheard of?
ID:	222355   Click image for larger version
ID:	222357   Click image for larger version
1967 RS/SS Coupe, Factory A/C, 2nd owner, original paint -Taho Turquoise 3 Spd on the floor, bench seat, fold down rear seat
1967 RS Convertible Factory A/C, PS, PB PG 327
Niblet is offline
post #2 of 74 (permalink) Old Oct 28th, 18, 08:29 AM
Re: Mini Starter Installation help, This is why I dont like to modify
Tim, Why didn't you just replace the original solenoid ?
Like you, I don't believe in the so called "upgrading" if
there isn't a solid need. There is virtually always a snowball
effect. I would return the mini started and go back to
original. If you keep it then you will have to shim as needed.
I've seen stacks of 5 or 6 shims used.
my 67' build thread:
allanjs is offline
post #3 of 74 (permalink) Old Oct 28th, 18, 08:33 AM Thread Starter
Tim
Thanks,,,there was an overwhelming bunch of folks who raved about the mini starters, so I thought,,what the heck,,
well they neglected to tell me about the "remote solenoid" or diode I would need and etc,,,yes had I known there was going to be more than 2 bolts and some shimming I would have bought an NOS solenoid and been done with it,,I'm committed now
so I'm going to see it through,,I just wanted to vent a little and caution others, when you modify something,,like Al said,,theres a snowball effect
Niblet is offline
post #4 of 74 (permalink) Old Oct 28th, 18, 08:43 AM
Tim, If you have headers then the mini starter is advantageous. Otherwise I see no gain, just pain.
allanjs is offline
post #5 of 74 (permalink) Old Oct 28th, 18, 08:59 AM
Tim, This may help you.
Niblet likes this.
Last edited by davidpozzi; Dec 22nd, 18 at 12:28 AM. Reason: The Camaro ign switch does supply power when cranking, but through a resistance wire.
allanjs is offline
post #6 of 74 (permalink) Old Oct 28th, 18, 09:34 AM
keith
X-77 keith's Avatar
I would go with one of the stock GM smaller starters. They bolt right up as the originals.
X-77 keith
X-77 keith is offline
post #7 of 74 (permalink) Old Oct 28th, 18, 09:47 AM
kevin
I have purchased mini starters from jegs and DB electrical and have NEVER used a shim
kv67ssrs likes this.
flat tire is offline
post #8 of 74 (permalink) Old Oct 28th, 18, 10:14 AM Thread Starter
Tim
where your clearances as tight as mine are in the pic above?
Niblet is offline
post #9 of 74 (permalink) Old Oct 28th, 18, 10:31 AM
If you are sticking with conventional ignition send it back. The juice is not worth the squeeze imho....
allanjs likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #10 of 74 (permalink) Old Oct 28th, 18, 11:02 AM
Vega$69's Avatar
Never had a problem with a mini starter install
Vega$69 is offline
post #11 of 74 (permalink) Old Oct 28th, 18, 11:16 AM
I run a tilton. Use its solenoid. I never have a problem. Itís self adjusting. No shims needed
40000-Series Super Starter - Tilton Engineering
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #12 of 74 (permalink) Old Oct 28th, 18, 11:43 AM
kevin
to be honest with you, I just bolted the starter on and hit the switch. it sounded good and spun the engine
I never checked nutin .
been using that one for 7 years. still no problems
69Z28 likes this.
post #13 of 74 (permalink) Old Oct 28th, 18, 11:57 AM
DjD
DjD's Avatar
I went with basically what GM put in new V8 cars. It was about $75, is very light weight, perm magnets (no heat soak) and has worked flawlessly for years!
gm chevy high torque chorme mini performance start
Niblet likes this.
...Dennis
DjD is offline
post #14 of 74 (permalink) Old Oct 28th, 18, 12:08 PM Thread Starter
Tim
so am I making these issues up? or am I just some kind of an idiot?
because quite frankly it was you who I took the advice from initially
Niblet is offline
post #15 of 74 (permalink) Old Oct 28th, 18, 12:12 PM Thread Starter
Tim
do you have breaker points? or Electronic Ignition?
Niblet is offline
