Wipers won't cut off - Team Camaro Tech
 3Likes
post #1 of 28 (permalink) Old Oct 31st, 18, 08:08 PM Thread Starter
Apprentice
Help
I have a 68 camaro that the wipers will not cut off, have replaced the wiper switch and the wiper motor and they still woot cut off, they were working ok one day and then they just wouldn't cut off, I don't know what to do next
Jaxfire307 is offline
post #2 of 28 (permalink) Old Nov 1st, 18, 12:05 PM
Steven
stamatisg1977's Avatar
Check ur wiring harness for frays or wire grounding out
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 28 (permalink) Old Nov 1st, 18, 12:15 PM
Lee
Re: Wipers won't cut off
Disconnect the connectors from the wiper motor except for the yellow power wire then turn on the key. Does the wiper motor still run? If so then there's a problem with the wiper park circuit inside the wiper assembly. If not then there's a wiring problem between the wiper switch and wiper motor.
dyno jonn likes this.
blitzer454 is offline
post #4 of 28 (permalink) Old Nov 1st, 18, 03:33 PM
Originally Posted by Jaxfire307 View Post
Help
Check the ground ring at the wiper motor
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #5 of 28 (permalink) Old Nov 1st, 18, 09:25 PM
Nick
it sounds like the park switch is not working right
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #6 of 28 (permalink) Old Nov 5th, 18, 07:23 AM Thread Starter
Apprentice
Disconnected wires and left only yellow wire, with ignition on nothing happens, this problem started with origional wiper motor and wiper switch, after problem started I replaced wiper switch and problem didn't go away so I bought a new wiper motor and that didn't fix problem, I did a bench test on wiper motor and motor parked perfect, this makes me believe its in the wiring so I ran new wires to high and low plug ins on wiper motor from wiper switch and motor still won't park so now I have no clue. Any guess, theory or just try this will be very appreciated, thanks
post #7 of 28 (permalink) Old Nov 5th, 18, 03:49 PM
Lee
That test indicates that the park switch is most likely okay, otherwise the motor would have started running as soon as you turned on the key. So next probe the light blue wire from the disconnected connector to chassis ground with the wiper switch off, and then do the same thing with the black wire. Both wires should be open when the switch is off. If that passes then turn the switch to low speed setting and confirm light blue wire now goes to ground and black wire is still high resistance. Then put the wiper switch to high setting and confirm both black and light blue wires go to ground. My guess is that either the light blue wire or the black wire is always at ground.
Do you have the wiper linkage and wipers all connected to the wiper motor? If not that might also explain the problem as the motor needs mechanical resistance in order for the park switch to work correctly.
post #8 of 28 (permalink) Old Nov 19th, 18, 01:12 PM Thread Starter
Apprentice
Thanks Blitzer, I did the tests you described, on low the light blue wire went to ground, but when I turned the switch to high both the light blue and black wires both did NOT go to ground, they both stayed open, the wiper switch is new and so is the wiper motor, what do you think is wrong with it ??
post #9 of 28 (permalink) Old Nov 19th, 18, 03:43 PM
Lee
It would seem you have another bad wiper switch as both the blue and black wires need to go to ground when the wiper switch is in the high setting. However this doesn't really explain the original problem of why the motor is running all the time when the wiper connectors are connected to the wiper motor. Or am I not understanding the problem incorrectly? I took you original post to mean that every time you turn on the ignition the wiper motor starts running, is that still the case? What were you using for ground for the negative meter lead? Are both the blue and green wires open when the wiper switch is off?
post #10 of 28 (permalink) Old Nov 20th, 18, 11:10 AM Thread Starter
Apprentice
Both wires have no reading, I am using a bolt in the firewall where 2 other wires are grounded to check for ohms blue wire ohms the other nothing, wipers stay on when ignition is turned on but if I manually park the motor by taking a wire loop and touching the high and low terminals on the motor together, then the wipers stay off once they are parked until I turn them on again then they will not stop by turning wiper switch off, do I need to buy another wiper switch?
post #11 of 28 (permalink) Old Nov 20th, 18, 11:13 AM Thread Starter
Apprentice
With switch off I have no reading on meter, with switch on and wiper switch to low blue wire shows a reading, on high wipers neither wire has reading
post #12 of 28 (permalink) Old Nov 22nd, 18, 11:00 AM
Jeff
yellow69RS's Avatar
Sounds like the wiper switch is not grounded. On a 69 there is a metal plate behind the headlight switch and the wiper switch with a wire on it that get screwed to the metal under the dash.
Jeff
yellow69RS is offline
post #13 of 28 (permalink) Old Nov 22nd, 18, 05:29 PM Thread Starter
Apprentice
Yeah I have that strap behind my gages being they are mounted in a plastic bezel but the wiper switch is mounted in the metal part of the dash, I also clamped a ground wire to my switch just in case it wasn't grounding through the dash but it didn't help.
Is there any was to test the wiper switch?
post #14 of 28 (permalink) Old Nov 22nd, 18, 05:51 PM
Yes you can test the switch but you need to know
how it is designed internally. My switch is out of
the car and I can test it and post the results but
I do not know for certain that it is good.
my 67' build thread:
allanjs is offline
post #15 of 28 (permalink) Old Nov 23rd, 18, 09:28 AM Thread Starter
Apprentice
Hello Allenjs, thank you for the help, I hate for you to go to all the trouble but at your convenience if you could check yours and post the results I could check mine and see how they compare it would be so much help, I have gone as far as I can on my own, you don't know how much I would appreciate it, no hurry, I'm not driving it if it looks like rain. Thank you very much.
