68 Tic Toc Tach Calibration - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 9th, 18, 06:12 PM Thread Starter
Dan
I purchased a used speedo and tic-toc-tach cluster on ebay a couple of weeks ago. It wasn't cheap and came untested but they don't show up all that often and I figured I'd take a chance. I've wanted to add a tach to my car for along time and wasn't happy with the idea of strapping one to the steering column. I also wanted OEM, just because. Nothing against the reproductions....
As you'd expect from 50 year old equipment that has been kicking around for who knows how long the tach wasn't very accurate. In fact it was off by 50%.
ID:	222643   Click image for larger version
1968 RS/SS 350 4sp Convertible
thegodown is offline
post #2 of 12 (permalink) Old Nov 9th, 18, 06:22 PM Thread Starter
Dan
Re: 68 Tic Toc Tach Calibration
Fortunately I'm not the first person to have this issue and replacement parts are available. However, I couldn't find any detail threads on how, so figured I'd post one.
The first thing I needed was a way to bench test the tach before and after the modifications. Fortunately I have a Megasquirt 2 system from another project that only required a few minor add ons to be able to test an old tach. This is the Megasquirt and Stimsim connected to my laptop and wired to an amplifier and relay coil to produce the signal required to drive the tach.
ID:	222647   Click image for larger version
post #3 of 12 (permalink) Old Nov 9th, 18, 06:27 PM Thread Starter
Dan
Here's a few pictures testing the tach before any changes. You can see the tach readings are 50% above the RPM's on screen for all ranges.
2,000 rpm's reads 3,000
3,000 rpm's reads 4,500
ID:	222651   Click image for larger version
post #4 of 12 (permalink) Old Nov 9th, 18, 06:33 PM Thread Starter
Dan
The Cajun Tach Shop sells replacement circuit boards for these old tachs on ebay, $30 delivered. Pretty sweet! Here's a picture of the 50 year old technology alongside the new.
ID:	222655   Click image for larger version
post #5 of 12 (permalink) Old Nov 9th, 18, 06:39 PM Thread Starter
Dan
Replacing the circuit board was pretty straight forward. The new board is a perfect fit. Carefully pull the spring clips off of the old board and replace them in the same locations on the new. Clip the new board into the plastic holder and your done. This is all pretty delicate stuff so obviously you want to be very gentle or you could break something. It's also very easy to lift the pot or variable resistor on the new board while applying pressure to the clips so be careful.
ID:	222659   Click image for larger version
post #6 of 12 (permalink) Old Nov 9th, 18, 06:43 PM Thread Starter
Dan
Reconnect the tach to the bench test setup and nearly perfect. Initially it was off by less than 10%. A few turns of the pot and it dialed right in to be a perfect match.
Now all I need to do is replace the clock mechanism with a quarts replacement and it will be as good as new and ready for installation into the car.
ID:	222663   Click image for larger version
post #7 of 12 (permalink) Old Nov 9th, 18, 07:34 PM
Lynn
Very nice of you to share. Wish there were something similar for the 69 tach. Mine reads high.
Lynn
bilodeaulynn is offline
post #8 of 12 (permalink) Old Nov 9th, 18, 07:43 PM Thread Starter
Dan
Should also work for the 69 tach. Search ebay for "NEW! 69-77 GM, Pontiac, Tachometer Circuit Board ~ Direct Replacement!" If you want confirmation, send an email to the seller. He's very responsive.
post #9 of 12 (permalink) Old Nov 9th, 18, 09:35 PM
Garth
Very cool. With your test equipment and expertise, I think you'd do well by offering your services !
Garfields Maro is offline
post #10 of 12 (permalink) Old Nov 10th, 18, 02:28 AM
Chris
ckaram's Avatar
Nice job walking us through it!
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #11 of 12 (permalink) Old Nov 10th, 18, 02:37 PM Thread Starter
Dan
Happy to share something useful for a change
post #12 of 12 (permalink) Old May 8th, 19, 07:38 PM
Brad
So, I have a 68 with electronic ignition and an OER tic toc tac. It seems to read pretty accurately at idle, then is way off (LOW) as the rpms go up. Anybody know if a tach filter would help with accuracy? Id also consider sending it out (to whoever?) to have it reworked? Any help or ideas would be appreciated. Thanx in advance.
bwarren is offline
