Blinker - Team Camaro Tech
 1Likes
  • 1 Post By wireboy355
post #1 of 4 (permalink) Old Nov 13th, 18, 08:44 AM Thread Starter
Probationer
gary
Blinker
Hi, we have a 68 with a ghost or something that turns the blinker on when the car isn’t running.. key isn’t even in the ignition.. any suggestions?
diefenderf is offline
post #2 of 4 (permalink) Old Nov 13th, 18, 09:10 AM
Jeremy
Re: Blinker
I would look at the emergency flasher switch. That has power when the key is in the off position.
satz28 likes this.
Jeremy
1967 rs, 355 sbc, Pontiac 867 heads, Crower rockers, Isky roller cam, FiTech Power Adder 600, Hurst Drivelines T-56 Magnum, RAM clutch, 4.10 posi, Vision 18" wheels
wireboy355 is offline
post #3 of 4 (permalink) Old Nov 13th, 18, 09:23 AM Thread Starter
Probationer
gary
Thanks, I’ll tell my husband tonight after work
post #4 of 4 (permalink) Old Nov 14th, 18, 05:15 AM
Kevin
Re: Blinker
Or, toss bones at the car and chant "ghost of relay, be gone"
I too would be pointing at the emergency flasher switch or emergency flasher relay sticking. These early Camaros used two flashers, one for the turn signal stalk on the steering column, and a second flasher for the emergency flasher switch button. If only one side of the car was flashing, I'd suspect the turn signal stalk. If all four are flashing, its the emergency flasher circuit.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
