electric fuel pump shut off switch - Team Camaro Tech
 1Likes
  • 1 Post By BPOS
post #1 of 10 (permalink) Old Nov 13th, 18, 09:17 AM Thread Starter
Ben
OK, so I'm running an electric in-line fuel pump and it's currently wired as per manufacturer specs with a fused line running from the battery + to relay, a keyed ignition source running to relay and the 'hot' line running from relay to fuel pump with pump grounded to chassis.
my question is this;
since the relay is triggered by the ACC post on the fuse box, the pump runs whenever the key is in the 'ON' or 'ACC' position. i'd like to run an in-line shut off so i can work on or test other electrical equipment without having the pump running full time. can i run a toggle switch in-line with the wire off of the fuse box 'ACC' and hide it under the dash to shut off the fuel pump when wanted?
i originally wired my ignition source in-line with my radio as a security measure for against theft...turn off the radio and fuel pump shuts off. well I'm also powering 2 amps from this source and recently installed a new radio that i was afraid of overloading with all that draw so ran the fuel pump direct to the 'ACC' post.
now when i want to fiddle with the radio or anything else, i have the fuel pump running......not good.
bhodgdon400 is online now
post #2 of 10 (permalink) Old Nov 13th, 18, 11:00 AM
Re: electric fuel pump shut off switch
Yes you have the correct idea. A single throw toggle switch will do what you want.
Big Dave
Larger Dave is offline
post #3 of 10 (permalink) Old Nov 13th, 18, 11:04 AM Thread Starter
Ben
that's what i thought. thank you
post #4 of 10 (permalink) Old Nov 13th, 18, 12:14 PM
On a 69 (don't know about 67,68) the IGN spade is hot when in run, not hot in ACC. ACC is hot in both positions as you know.
DT likes this.
BPOS is offline
post #5 of 10 (permalink) Old Nov 13th, 18, 03:43 PM
Good suggestions of Dave and Al, you could power relay coil by using the IGN spade on fuse panel, but won't be secure as using radio power.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #6 of 10 (permalink) Old Nov 13th, 18, 04:58 PM
Yes, can be done.
I have a hidden micro toggle switch wired in just like you're wanting to do.
68 Camaro~LSx ~all motor
post #7 of 10 (permalink) Old Nov 14th, 18, 05:10 AM
Kevin
You'd be fine keeping it this way, since you are using this radio lead as the "trigger" for the relay that then powers the fuel pump. That's how a relay works. It uses a low current "trigger": to operate the relay that supplies a higher amp lead to the source (in your case, the fuel pump.
If I may ask, what electric fuel pump are you using? Is this for a fuel injection setup?
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #8 of 10 (permalink) Old Nov 14th, 18, 06:15 AM
Ed
I did the same thing on my Camaro and hid the switch in the interior so if someone tried to steal it they would be 5h1t out of luck!!! LOL!!!
ZEN357 is offline
post #9 of 10 (permalink) Old Nov 14th, 18, 06:49 AM Thread Starter
Ben
using Edelbrock quiet flow 160 GPH external in-line pump. carb set up.
post #10 of 10 (permalink) Old Nov 14th, 18, 10:15 PM
Rich
I had a hidden switch in my C10 truck that would cut the ground to the fuel pump and it would not work. I liked this a lot better no chance of an accidental shock.
1967 SS350, Under construction.
H20cooled is offline
