Headlight doors will not close with LED headlights - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 3rd, 18, 08:05 AM Thread Starter
Andrew
I have a 1967 Camaro RS with headlight doors. When I replace the factory halogen 7" headlights with LED headlights, my headlight doors will open, but they will not close when the lights are turned off. I have read that this is because the door close circuit relies on ground through the headlight filaments. If you convert to HID headlights then the ground circuit may not exist or be enough.
Will a resistor installed in-line between the headlight wire and the body ground correct this issue? If so, what size or load?
https://www.theretrofitsource.com/mo...-resistor.html
frascona is offline
post #2 of 4 (permalink) Old Dec 3rd, 18, 10:12 AM
Re: Headlight doors will not close with LED headlights
Seven and a half (7 1/2) ohms) 40 watts.
However, stock shelf size of both specs is 8 ohm and 50 watts.
This would work:
https://www.newark.com/ohmite/hs508r...nd/dp/73AC6537
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
post #3 of 4 (permalink) Old Dec 3rd, 18, 11:38 AM Thread Starter
Andrew
But will a resistor solve the issue? From my understanding, the LED lights eliminate the ground through the old headlight filament. So will adding a resistor help? If so, what wire should it be spliced to?
frascona is offline
post #4 of 4 (permalink) Old Dec 3rd, 18, 01:29 PM
Lee
Yes, adding a resistor will work. You can connect it to the headlight door circuits light blue wire then to ground. Also read this thread for another alternative.
blitzer454 is offline
