What is this connector for ? Under dash - Team Camaro Tech
 5Likes
  • 2 Post By eville
  • 1 Post By allanjs
  • 1 Post By allanjs
  • 1 Post By bertfam
post #1 of 14 (permalink) Old Dec 4th, 18, 12:01 PM Thread Starter
Anybody know what this connector is for ? It's under dash close to the
center. It is in the same harness as the courtesy light wiring. I'm guessing
it is for some type of accessory that I don't have but not sure what.
Thanks for the help.
my 67' build thread:
allanjs is offline
post #2 of 14 (permalink) Old Dec 4th, 18, 12:23 PM
Camarodude67
Re: What is this connector for ? Under dash
I would bet it is for the AM radio...
camarodude67 is offline
post #3 of 14 (permalink) Old Dec 4th, 18, 12:30 PM Thread Starter
Nope. The radio is a 3 spade connector. Thanks.
allanjs is offline
post #4 of 14 (permalink) Old Dec 4th, 18, 01:20 PM
pink and green is backup lights I think.
130fe and dhutton like this.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #5 of 14 (permalink) Old Dec 4th, 18, 01:24 PM
Should connect to the reverse light switch on the console shifter if I remember right.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 14 (permalink) Old Dec 4th, 18, 01:32 PM Thread Starter
The car didn't come with a console but that connector may
have been included just like the courtesy light harness.
I struggle with colors (particularly red) but the wire looks
red, not pink, too me. I can't find it identified in any of the
wiring diagrams yet. I'll keep looking and keep the suggestions
coming. Thanks guys.
allanjs is offline
post #7 of 14 (permalink) Old Dec 4th, 18, 01:33 PM
Patrick
Do you have three gauges in the center console? If so, it could be for the temperature gauge. Temperature uses a green and pink wire. I own a Firebird so don't take what I say as being correct.
Money can't buy you happiness but it can buy you car parts which is bout the same thang.
Patrick
tp_smith is offline
post #8 of 14 (permalink) Old Dec 4th, 18, 01:54 PM Thread Starter
Patrick, No center console from the factory. I am adding it though.
allanjs is offline
post #9 of 14 (permalink) Old Dec 4th, 18, 02:47 PM
Patrick
Every time I work with wires, I think of my favorite quote from Ernest.
"My daddy use to work on them."
Now I got it ingrained into your head.
Patrick
tp_smith is offline
post #10 of 14 (permalink) Old Dec 4th, 18, 04:28 PM Thread Starter
I think I got it figured out after you guys said you thought it was the
back lights. Apparently I have the harness laying on the wrong side
of the steering column. Imagine that. It's only been a decade since
I removed the original column. Looks like it goes to the column mounted
neutral safety/back up light combo switch. The car was originally a 3 on the
tree. I've got to do a little more searching but pretty sure that's it.
Thanks guys. I still say the wire is red. LOL
130fe likes this.
allanjs is offline
post #11 of 14 (permalink) Old Dec 4th, 18, 04:30 PM Thread Starter
https://www.youtube.com/watch?v=F0wdVgPMY9A
Thanks Patrick. And my dad has the ultimate set of tools. He's a TV repair man. One of my favorites.
53Crestline likes this.
allanjs is offline
post #12 of 14 (permalink) Old Dec 5th, 18, 08:02 AM
Matt
It is the back up light switch connector. It connects to the back up light switch that mounts on the top side of the steering column closer to the floor board by the pedals.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #13 of 14 (permalink) Old Dec 5th, 18, 09:12 AM Thread Starter
Yes I have verified that is indeed the backup light connector. Here is an interesting
note. I dug out the original 3 on the tree column. The pics show the switch. The
interesting thing is it includes a neutral safety switch. I verified the neutral safety
switch side does indeed function as it should in neutral. There is no purple wire
and purple/white wire as was used with the nss function. I realize manual shift
cars did not use a nss, as it's been documented many times, but just a bit baffled
as to why the switch would have been included but not utilized. It is possible the
switch was replaced at some point and it's not factory original.
Thanks guys for the help.
allanjs is offline
post #14 of 14 (permalink) Old Dec 5th, 18, 09:27 AM
Ed
bertfam's Avatar
That switch (P/N 3909537) is the correct switch for (among others) all 67-68 with the 3 speed manual transmission (column shift), and it didn't use the NSS half. I guess GM decided it wasn't worth designing another switch just for the backup lights.
Ed
allanjs likes this.
Ed B. (but you can call me Bert!)
CRG -
bertfam is offline
