American Autowire aaw - Team Camaro Tech
 1Likes
  • 1 Post By stamatisg1977
post #1 of 13 (permalink) Old Dec 8th, 18, 10:10 AM Thread Starter
Kevin
In the process of swapping out my harness for the aaw classic direct fit harness. Went to mount the fuse block and it is hitting the parking brake switch making it not work. Have any of you done this harness and if so what did you find was the easiest way to address the issue?
NH427 is offline
post #2 of 13 (permalink) Old Dec 8th, 18, 12:06 PM
Re: American Autowire aaw
That pesky e brake pedal is always in the way. I use an E-Stopp in all my builds now.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 13 (permalink) Old Dec 9th, 18, 09:33 AM
Rob
rlw68's Avatar
Is the AAW fuse block larger than the original?
Rob
1969 Camaro Z/28. Norwood 02D. Lemans Blue
rlw68 is offline
post #4 of 13 (permalink) Old Dec 9th, 18, 11:00 AM Thread Starter
Kevin
It is slightly larger and has side clips for what I would assume is for adding another unit too it and clipping together. I used my dremel and just cut the tab off. Going to be so nice to not have anymore wiring gremlins. Install besides this has been beyond easy
NH427 is offline
post #5 of 13 (permalink) Old Dec 9th, 18, 11:33 AM
Tim
I am curious how you address the terminal ends for the lights? I am assuming you simply wire the new harness into the original taillight, running light or headlight sockets? I am going to purchase the same harness but wasn't really clear on what was included or not. Any insight would be appreciated.
Shannon4570 is offline
post #6 of 13 (permalink) Old Dec 9th, 18, 11:59 AM
Kit comes with all new sockets.
dhutton is offline
post #7 of 13 (permalink) Old Dec 9th, 18, 12:40 PM
Chick
68camaroz28's Avatar
Don is correct the harness comes with all sockets attached but some of them are not technically correct and probably most at least change out the headlight sockets as they come white vs. the originals that are brown. There are several other little things and depends on how correct you want the harness. Some things are quite easy to change like the alternator rubber boot (take off original harness & swap out) and some other things are a little more involved like the plastic push in connectors (radiator support) as they come white and originals were black.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #8 of 13 (permalink) Old Dec 9th, 18, 12:57 PM
keith
X-77 keith's Avatar
the update kit is the kit where you need to put some of the connectors on. The kit uses flat blade fuses and has provisions for extra things like fuel pump, fans, and A/C. If you are going custom that may work better for you.
X-77 keith
X-77 keith is offline
post #9 of 13 (permalink) Old Dec 9th, 18, 12:57 PM
I donít think folks using the classic update kit with modern style fuses etc are worried about correctness, are they? At least I would not use one if I wanted it to be correct. There are likely better options for that.
dhutton is offline
post #10 of 13 (permalink) Old Dec 9th, 18, 01:43 PM
Chick
Correct and was thinking (bad on me) that kit was the original type kit. I'd still change those headlight connectors if they are white in that kit also.
Chick
Our 68Z Restoration
post #11 of 13 (permalink) Old Dec 9th, 18, 02:52 PM
You are an originality machine...
dhutton is offline
post #12 of 13 (permalink) Old Dec 9th, 18, 03:16 PM
Steven
stamatisg1977's Avatar
I like how the kit comes with extra wire and spots in the fuse panel to power an ecm if you are going LS or any aftermarket fuel injection
Jim Huffman likes this.
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #13 of 13 (permalink) Old Dec 9th, 18, 04:53 PM Thread Starter
Kevin
Unlike the painless kit the aaw classic does use the same firewall plugin but like others said some of the colors are off. I have only started doing the interior and so far the headlight switch should have a blue wire for my Detroit speed headlight covers but it was not blue like the factory. Also the ignition wires had a few that were not the same. Like said this is not for the guy looking all original but the guy like me with a pro touring build and a ton of extras. This kit allows me to clean up the mess from having power windows, door poppers, alarm, line lock, cut outs etc So far the classic update kit is exceeding my expectations
NH427 is offline
