Reverse Light Switch - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 14th, 18, 11:01 AM Thread Starter
Randy Brutout
Randy Brutout's Avatar
Can someone tell me where the reverse light switch is on a 68' SS Muncie 4 speed? I don't see any wires going to the transmission nor shifter.
Thanks!
Randy Brutout is offline
post #2 of 7 (permalink) Old Dec 14th, 18, 11:45 AM
Ed
bertfam's Avatar
Re: Reverse Light Switch
The switch is mounted on the transmission (see attached) and the cables run up to the FIREWALL CONNECTOR ("Backup light hole 67 & 68 only").
Ed
Ed B. (but you can call me Bert!)
CRG -
bertfam is offline
post #3 of 7 (permalink) Old Dec 16th, 18, 07:30 PM Thread Starter
Randy Brutout
Thanks Ed!
post #4 of 7 (permalink) Old Dec 16th, 18, 08:34 PM
Pete
Ed
If you have a Hurst shifter, the reverse switch actually mounts on the shifter. The rear stop holds it in place.
68lowered is offline
post #5 of 7 (permalink) Old Dec 17th, 18, 09:31 PM
Farm Boy's Avatar
The reverse lever in the picture bertfam posted is a Hurst part. It came with the hole for the factory 1967-68 reverse light linkage drilled. I know this because it's my transmission in the picture.
I prefer the factory switch over the Hurst switch. Connecting the factory switch to the Hurst reverse lever is a piece of cake.
Farm Boy is offline
post #6 of 7 (permalink) Old Jan 22nd, 19, 11:29 AM
Apprentice
Jeff
If you have no Firewall Connector to plug in the wires from the transmission, where can you find the Plug-in? Would it be mounted on the steering column like some photo's show.
gremmen is offline
post #7 of 7 (permalink) Old Jan 22nd, 19, 11:48 AM
Ed
bertfam's Avatar
Yes, check out the AIM, UPC 12, sheet C2 for more information.
Ed
CRG -
bertfam is offline
