Positive Sidepost Cable - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 2nd, 19, 07:11 PM Thread Starter
Bruce
What is the length of the positive side post battery cable for a 350, 69 Camaro?
The Camaro Guy is offline
post #2 of 3 (permalink) Old Jan 3rd, 19, 04:39 AM
kevin
Re: Positive Sidepost Cable
google is your friend
sdkar
Hero Member
View Profile
Re: What are the correct lengths for 69 Camaro side post battery cables?
« Reply #1 on: April 02, 2012, 05:15:22 AM »
I have found the answer to this question just in case anyone is interested.
The proper length for side post battery cables are the following:
Small Block (302, 307, 327, 350) - (Positive is 43-3/4") and (Negative is 34-1/2")
Big Block (396, 427) - (Positive is 45-1/2") and (Negative is 29-1/2")
The main length of the cables are black regardless of positive or negative with the "heads" that contain the bolt that attaches to the battery color coded in red for positive and black for negative.
Hope this helps.
flat tire is offline
post #3 of 3 (permalink) Old Jan 3rd, 19, 07:00 AM Thread Starter
Bruce
Thanks Kevin. Decided to go side as it gives a cleaner look and it was a late model change from top cable.
