Dumb Question - Team Camaro Tech
 4Likes
  • 1 Post By Yellow69RSZ
  • 1 Post By rogerh
  • 1 Post By Everett#2390
post #1 of 9 (permalink) Old Jan 5th, 19, 06:49 PM Thread Starter
Dumb Question
Hi Sorry for the Dumb Questions i having owned a Classic for a long time so her goes
1 should the gas gauge stay at the amount in the tank even with the key off
2 should the Speedo and gas gauge lite always be on when the key is on
3 should the headlamp switch dim the Speedo and gas gauge lamps when i turn the knob
Sorry so used to my new Silverado But Thanks !!!!
Kelcel is offline
post #2 of 9 (permalink) Old Jan 5th, 19, 08:30 PM
Re: Dumb Question
My best guesses...1. Not necessarily
2. I don't believe so
3. Yes
Kelcel likes this.
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline
post #3 of 9 (permalink) Old Jan 5th, 19, 09:00 PM Thread Starter
Re: Dumb Question
3. Yes
I think first off i need a new Head Lamp Switch not sure
Kelcel is offline
post #4 of 9 (permalink) Old Jan 5th, 19, 09:22 PM
Roger
rogerh's Avatar
Re: Dumb Question
There is no dumb question and the answer to these are,
#1. No, the fuel gauge is electric and when you turn off the ignition it turns off the electric to the gauge.
#2. No, normally the dash light are not on unless the headlights or parking light are on.
#3. Yes, the headlight switch also controls the brightness of the dash lights and manually turns on the dome/interior lights. It doesn’t control the light in the radio. The radio light is only on when the radio is on.
These answers for a 67. A 68 or 69 my be different. In the future it would help to post what year Camaro you have.
Below is a picture of the page in the manual that tell how the headlight switch should work.
Kelcel likes this.
rogerh is offline
post #5 of 9 (permalink) Old Jan 5th, 19, 09:36 PM Thread Starter
Re: Dumb Question
oh yes you are right Thanks i have a 1969 just changed my fuel sending unit it reads right but stays at the same level key on or off not sure what that is ??
and the bottom left fuse "ACC " had no power and when i give it power the dash sights come on as soon as i turn the key on and #3 im pretty sure i need a head lamp switch i can turn the knob and it doesn't change the lights at all Thanks Again !!
Kelcel is offline
post #6 of 9 (permalink) Old Jan 6th, 19, 06:31 AM
Re: Dumb Question
Good answers given. Gas gauge may stay at powered on indication when power is OFF. However, the needle may move if not at 12 o:clock position when power is turned off due to gravity.
Look for a gray wire, as this color wire is dash lights power. If connected to ACC spade on fuse panel, yes, they will come on and yes, no dimming via light switch as light power source may have been relocated from headlamp switch to fuse panel.
Once you find gray wire, when you connect to headlamp switch, dimming function may work.
Tip: when operating dash light dimmer, twist the bejesus on it to remove any burnt spots on potentiometer so lights will dim/brighten when turned.
Kelcel likes this.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
Everett#2390 is online now
post #7 of 9 (permalink) Old Jan 6th, 19, 09:21 AM Thread Starter
Re: Dumb Question
Thanks for that info i do see 1 grey wire looks like its to the head lap switch here is what i have
3 fuses on left in fuse block always hot
5 fuses on right in fuse block only hot with ignition on
bottom small LPS no power at all
Dash lights will not go on even when head lamps are on unless i jump power to the LPS fuse then they come on when the key is on
hope this makes sense Thanks !!
Kelcel is offline
post #8 of 9 (permalink) Old Jan 6th, 19, 12:53 PM
Re: Dumb Question
Then LPS power is not coming from headlamp switch to fuse panel.- Dark green into panel.
Kelcel likes this.
post #9 of 9 (permalink) Old Jan 6th, 19, 01:25 PM Thread Starter
Re: Dumb Question
Thanks i will look for that but is the rest right
hot all the time and hot with ign ? Thanks and should that LPS be hot only with ignition on ? thanks
Kelcel is offline
