1968 center console - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 21st, 19, 05:54 PM Thread Starter
1968 center console
I'm connecting a center console with guages wire harness to my under dash wire harness. The center console wire harness has a different connector then the under dash connector to console. The under dash has about 3 different wire bundles going to the console. I just want to clean it up some. Where can I get the under dash to console connector and pins to make one wire harness to the console?
1968 RS/SS 396 owned since High School
Devor is offline
post #2 of 6 (permalink) Old Jan 21st, 19, 06:30 PM
Tom Anderson
Re: 1968 center console
Try Classic Industries
socal_tom is offline
post #3 of 6 (permalink) Old Jan 21st, 19, 06:53 PM Thread Starter
I did and they didn't have anything.
Devor is offline
post #4 of 6 (permalink) Old Jan 21st, 19, 09:20 PM
Tom Anderson
Steves camaro parts or maybe heartbeat city
post #5 of 6 (permalink) Old Jan 22nd, 19, 04:52 PM
69-Pace's Avatar
Exclamation Re: 1968 center console
Try M & H - Reproduction Wiring Harnesses for America's Muscle Cars
but would call them (562) 926-9552
Also try Lectric Limited https://www.lectriclimited.com/
Local - (708) 563-0400
Toll-Free - (866) 624-1850
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Jan 23rd, 19, 03:29 AM
Kevin
While not OEM type connectors, I went to Ebay and found 2,4,6,and 8 pin connectors. I ended up using a pair of 4 pin connectors. In my case, my 67 has a center console and the reproduction gauge holder, but the three gauges in it are not the factory gauges, but rather an aftermarket oil, engine temp, and AMP gauge setup.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
