1968 RS Conversion - Team Camaro Tech
View Poll Results: What do you guys suggest is the best ?
DSE 1 100.00%
Retro Electro 0 0%
any other brands out there 0 0%
Voters: 1. You may not vote on this poll
post #1 of 9 (permalink) Old Mar 26th, 19, 11:14 AM Thread Starter
Dan
1968 RS Conversion
Hi, I know it's been talked about alot on here but finally gonna buy it. I already have a RS car but vacuum setup , looking to buy the Electric upgrade . What is the consensus on here on which set up to buy ? Thanks alot
vwdubs1 is offline
post #2 of 9 (permalink) Old Mar 29th, 19, 01:52 PM Thread Starter
Dan
Re: 1968 RS Conversion
Anyone ???
vwdubs1 is offline
post #3 of 9 (permalink) Old Mar 29th, 19, 04:46 PM
Iíve used Retro Electro and Detroit Speed. I prefer Retro Electro by far.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 9 (permalink) Old Mar 30th, 19, 07:35 PM
My car is a 67. There may be differences in what you have. This is a Retro Electro setup. I just got it Friday. I don't think the DSE setup was an easy fit on my car. I didn't follow the directions to a T. I elected to cut out the bracket where the interference exists rather than deform the bracket and I mounted the controls solid. There was more interference than I suspected. As you can see a LED headlight with a fan setup out back is a non starter.
ID:	226021   Click image for larger version
ID:	226023   Click image for larger version
3d cad is offline
post #5 of 9 (permalink) Old Mar 30th, 19, 08:13 PM
Retro Electro for a 69 doesnít look anything like that, assuming i assembled it correctly. LED headlights with a fan fit fine in my case. Not sure how a 68 compares to 67 vs 69.
Edit: 68 is similar to 67 per their instructions.
dhutton is offline
post #6 of 9 (permalink) Old Mar 31st, 19, 04:32 AM
The Retro setup is the 67 setup upsized. Based on what I see in CHQs parts list a 69 is very different due to the lack of common parts but a 68 shares parts. There is enough parts sharing that I suspect the bellcrank on a 68 is on the same centerline as a 67 and the motor winds up on the same centerline as mine. Thatís speculation on my part though.
I need to talk to Mark at Retro because I wonder if I need to put the original switches, or parts of similar shape, back in to serve as travel stops.
One door still has what appears to be a soft channel bump stop on it. There was a glue mark on the drivers side where one existed there also.
3d cad is offline
post #7 of 9 (permalink) Old Mar 31st, 19, 07:03 AM Thread Starter
Dan
Seems like more guys go with the electro setup Is it easier to install ? What LED headlight are o guys running ?..
vwdubs1 is offline
post #8 of 9 (permalink) Old Mar 31st, 19, 07:18 AM
Retro Electro design is much cleaner than DSE imho. DSE design is a kludge imho. Bandaids on the bandaids....
dhutton is offline
post #9 of 9 (permalink) Old Mar 31st, 19, 07:47 AM
I agree with Don that Retro is cleaner. You can go to both websites and read/download their installation directions. That may help you decide. there is interference between the Retro motor and the mount that has to be addressed. I believe mine is a little more than what was expected by Retro though thats speculation on my part. I elected a cut off wheel and a finger sander over a hammer. I am somewhat used to finding that my cars parts don't always match up with others though. I looked at the instructions for a 68 and I suspect that Chevy figured out how to bolt a bellcrank setup into the motor mount location they made for 67 and your experience will somewhat mirror mine. Don's right that its bandaids on bandaids.
3d cad is offline
1968 Camaro Stock Wheels and Tires tommy68 Wheels & Tires 3 Mar 16th, 19 10:32 PM
Yet another auto to manual conversion thread! X44 Transmission & Driveline 12 Jun 3rd, 18 05:55 AM
1968 Camaro Tic Toc Tach Disassembly & Quartz Conversion Camaros-n-Chevelles Restoration Corner 4 Dec 1st, 17 07:15 AM
1968 Z/28 build Fortes Parts Connection Camaro Tech 12 Nov 25th, 17 06:11 AM
