67 console wiring - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 29th, 19, 11:02 AM Thread Starter
Big daddy
67 console wiring
I have a 67 that was a 3 spd in the flr. got a console now going 2004r got console wiring.So now I need to get n/s. I think there is no place to plug in plug on the harness. Will I have to remove plug and wire in seperate.?
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 7 (permalink) Old Mar 29th, 19, 11:43 AM
Re: 67 console wiring
I'm in the process now with my 67. I bought the Shiftworks overdrive shifter. It comes with
the neutral safety switch and back up lights switch. Yes you will have to splice into your wiring
harness for the n/s switch. Purple wire from ignition switch. Or you can continue to run without
the switch.
my 67' build thread:
allanjs is offline
post #3 of 7 (permalink) Old Mar 29th, 19, 02:16 PM Thread Starter
Big daddy
ok,I have the same,I know I will have to splice, trying to fig if I have to splice both purple wire to ignition and starter.
carhodge is offline
post #4 of 7 (permalink) Old Mar 30th, 19, 10:08 AM
The n/s switch needs to be in the purple line to the ignition switch only. Shown in the
AIM UPC12 D3.
allanjs is offline
post #5 of 7 (permalink) Old Mar 30th, 19, 12:13 PM Thread Starter
Big daddy
I have two heavy purple wires from console harness,I guessing both spice into ignition wire? I think iam getting this.
carhodge is offline
post #6 of 7 (permalink) Old Mar 30th, 19, 12:17 PM
69-Pace's Avatar
I'm moving this tread from the website issues section to electrical.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 7 (permalink) Old Mar 30th, 19, 02:32 PM
Think of the harness wires as extensions. Hopefully this will help.
allanjs is offline
Questionable Wiring in '67 Camaro Conv' Andrew69 Electrical & Wiring 15 Feb 4th, 19 11:47 PM
Console gauges and wiring. Sam 15 Electrical & Wiring 4 Aug 6th, 18 09:07 AM
console wiring carhodge Electrical & Wiring 6 Jul 1st, 18 11:38 AM
67 Console Wiring Question ScudRunner Electrical & Wiring 4 May 30th, 18 01:57 PM
