68 bulkhead connector schematic - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 7th, 19, 07:08 PM Thread Starter
Probationer
Doug
I have searched this forum and read that the electrical diagrams went "dark" for various reasons. I have a full 68 wiring schematic which I have used to do almost all of my rewiring as it was badly hacked when I bought it - long story. What I cannot find is a CLEAR schematic of the pin-out of the 68 bulkhead connector. The I know what wires pass through, but not which one is which coming out of the connector. The bulkhead connector is a right and left side, which are mirrored. The right side has 4 pins on the top and bottom row, and 3 on the second and third row. I will attach a picture if possible. Any help with this would be appreciated.
Name:	Bulkhead connector.JPG
After 44 years, have both the 68 and 69 Camaro
Let the resto begin
dcoil is offline
post #2 of 4 (permalink) Old Apr 8th, 19, 05:52 PM
69-Pace's Avatar
Exclamation Re: 68 bulkhead connector schematic
Hello - Can you do me a favor and fill in your name and location on your profile?
Here are 1967, and 1968/69 bulkhead routing diagrams in color. The PDF is not color but lists the actual wire purpose and color. In theory these should match. Note that in both "Before Conversion" = standard non console gauges, and "After Conversion" = with console gauges installed.
Name:	1967 bulkhead connector.JPG
ID:	226255   Click image for larger version
Name:	1968 1969 Bulkhead connector 68 69 fuse panel.JPG
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Apr 10th, 19, 04:08 AM
Kevin
Good stuff! Printed, and placed into my cook book.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
post #4 of 4 (permalink) Old Apr 13th, 19, 02:44 PM Thread Starter
Probationer
Doug
Oh yes, exactly what I was hoping for. Thanks 69-Pace. And yes, I will fill in my info. Best, Doug
Let the resto begin
dcoil is offline
Time for another 68 Z/28 to be restored 68camaroz28 Build Projects 1410 Jan 13th, 20 08:42 PM
MacNeish certified '68 Z/28 Charlie Dawson Restoration Corner 7 Jul 26th, 18 05:16 PM
'69 in a '68? kalel14 Interiors 11 Mar 8th, 18 03:29 PM
Can I use 1969 door panels and rear panels on my '68? kookykrispy Camaro Tech 4 Dec 13th, 17 09:47 PM
