'67 Camaro 396 Starter Woes - Team Camaro Tech
 4Likes
post #1 of 25 (permalink) Old Apr 15th, 19, 05:45 PM Thread Starter
Andrew
Andrew69's Avatar
I replaced the starter on this 396 engine. I noticed the starter I removed had several shims under the outer bolt to angle the starter toward the flex plate. The new starter from DB Electrical I first mounted with no shims.
This starter: https://www.dbelectrical.com/product...t-sdr0059.html
When I turned the key the starter gear chattered but the engine did not rotate.
Thinking maybe the starter gear is too close to the flex plate I added one shim. When I turned the key I had the same results, the starter chattered but the engine did not rotate.
So I added a 2nd shim and this time the starter gear turned with no contact with the flex plate.
This told me that the starter gear is too far from the flex plate. So I removed the starter and shims, ground a little clearance in the transmission dust shield, and reinstalled with a washer under the outer bolt to angle the starter toward the flex plate.
Now the car will start but I don't believe the starter is meshing correctly to the flex plate. And I don't like it mounted at an angle.
What am I missing? Could this engine have too small diameter of a flex plate? Might I have a 153 tooth flex plate when it should have a larger one? Should I get another design of starter?
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #2 of 25 (permalink) Old Apr 15th, 19, 06:04 PM
Re: '67 Camaro 396 Starter Woes
You can use a medium size paper clip for the wire to test adjustment.
Without a proper mesh (why there exist shims in the first place) it will never work and you will just eat the start ring gear off the flex plate and bur the pinion gears.
Big Dave
Larger Dave is offline
post #3 of 25 (permalink) Old Apr 15th, 19, 06:47 PM
DT
Donny
DT's Avatar
Iím not a fan of those DB starters. I would install a quality full size starter from PowerMaster. Mine was #3689 (4 speed). I had zero issues. Headers too. Just my .02
Last edited by DT; Apr 16th, 19 at 08:11 AM. Reason: POWERMASTER NOT POWERHOUSE LOL
DT is offline
post #4 of 25 (permalink) Old Apr 15th, 19, 09:09 PM
Andrew, I would first determine the number of teeth on the flex plate. Because the stater you removed
was shimmed at an angle and the new starter required the same I wouldn't blame the starter. I just
installed the exact same starter and it works just fine with no shims. Mine is a small block.
my 67' build thread:
allanjs is offline
post #5 of 25 (permalink) Old Apr 16th, 19, 06:20 AM Thread Starter
Andrew
Andrew69's Avatar
Big Dave
How does one get the starter to extend the gear to mesh to utilize the paper clip? Please excuse my ignorance but this I have never figured out.
Originally Posted by DT View Post
Iím not a fan of those DB starters. I would install a quality full size starter from Powerhouse. Mine was #3689 (4 speed). I had zero issues. Headers too. Just my .02
I have the same DB starter on my 302 engine since about 2005. It was bolted on with no shims and has worked flawlessly. The Powerhouse might very well be better quality but thus far I'm good.
I'm working from the garage floor with the car on jack stands. Pulling the auto transmission to resolve this concern is something I really want to avoid. And tomorrow I'm scheduled to have a dual exhaust installed. Once the exhaust is installed pulling the tranny becomes more difficult.
Will a starter that installs in the adjoining holes, instead of staggered holes, tighten the mesh of the gears?
Skunk Works
Some photos:
Member # 159
post #6 of 25 (permalink) Old Apr 16th, 19, 06:35 AM Thread Starter
Andrew
Andrew69's Avatar
I find this conversation that says some 396 blocks had the starter mount holes drilled 0.100" offset. Anyone heard of this before?
https://www.chevelles.com/forums/45-...e-what-do.html
Skunk Works
Some photos:
Member # 159
post #7 of 25 (permalink) Old Apr 16th, 19, 07:11 AM
Was the original set-up - OE starter & shims- working?
If not broke, or starter needs a rebuild, why not rebuild OE starter and use the same nose piece & shims?
"If it ain't broke, don't fix it."
Dave Nelson likes this.
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
Everett#2390 is online now
post #8 of 25 (permalink) Old Apr 16th, 19, 07:36 AM Thread Starter
Andrew
Andrew69's Avatar
The starter on the car was "working" but it too was not engaging correctly. With the headers I've installed on this car I want to convert to a newer smaller starter.
Might this design allow enough mesh adjustment to resolve my concern? https://www.dbelectrical.com/product...saAmCrEALw_wcB
Skunk Works
Some photos:
Member # 159
post #9 of 25 (permalink) Old Apr 16th, 19, 08:01 AM
You can pull it out with a screw driver as it it slides easily and the spring that retracts the gear isn't that strong.
Mini starters are purchased by GM from Hitachi. All modern cars and trucks use them so a factory quality starter can be had used in junk yards.
Big Dave
post #10 of 25 (permalink) Old Apr 16th, 19, 08:07 AM
Andrew, If you remove the spark plugs you can use a flywheel turning tool to
rotate the engine allowing you to count the number of teeth on the flexplate.
I think you can rent the tool from Autozone or the like for free. For checking
starter drive engagement there is a slot on the bottom of the starter nose you
can fit a very small screwdriver in to slide the drive gear outward. It's a tight
fight especially laying on your back but it's doable. I did it.
allanjs is offline
post #11 of 25 (permalink) Old Apr 16th, 19, 08:21 AM
DT
Donny
DT's Avatar
Verify: A starter for a 12 3/4" 153tooth flexplate has a straight bolt pattern. A starter for the 168 tooth flexplate has a staggered bolt pattern.
jimnecci likes this.
DT is offline
post #12 of 25 (permalink) Old Apr 16th, 19, 08:48 AM Thread Starter
Andrew
Andrew69's Avatar
I'm thinking this is the 153 tooth flexplate and someone previously used the staggered bolt pattern starter when it should be straight. I purchased staggered bolt because that is what was on it. I'll try a straight bolt pattern starter.
If I have to pull the plugs to count the teeth I will do so.
I talked to Josh at DBElectric who recommends this starter with the straight bolt pattern. https://www.dbelectrical.com/product...-hp-mt200.html
A story from long ago: About 1978 I purchased a used '74 Datsun 260Z that kept burning up the distributor rotor. When that occurred I would remove the burnt rotor and replace it with another just like it.
After several incidents I just asked for the correct rotor and was given one with a longer arm moving the contact points closer. I argued with the counter guy it was incorrect but he said their books said it was. That rotor never burned up. Someone had utilized the wrong rotor, probably just to get the car running for as cheap as possible, and it had been biting me in the butt. I was glad I stumbled upon the solution.
Skunk Works
Some photos:
Member # 159
post #13 of 25 (permalink) Old Apr 16th, 19, 09:06 AM
DT
Donny
DT's Avatar
I hope you get it sorted out. My DB starter lasted a week on my 396 and I have been sour on them ever since. I'm sure yours will be fine, I had a lemon LOL.
DT is offline
post #14 of 25 (permalink) Old Apr 16th, 19, 09:26 AM
Jon
Like talking to the wall..... Most everyone thinks hot rod stuff is better than the way GM did it, even though the hot rod stuff has to be modified to make it work. It's just a fact of life, I guess.
Jon N
dyno jonn is offline
post #15 of 25 (permalink) Old Apr 16th, 19, 06:12 PM
scblucam's Avatar
Agree completely. It took me so long to find one that worked correctly and quietly. When it got weak I ordered a "mini", big mistake couldn't even bolt it up, sent it back. Took the one I had to a starter shop with a big tag "REBUILD THIS ONE. NO EXCHANGE". It has been probably 15 years and going strong. I think I have the 168 tooth flywheel since I run a 11" clutch. Been a long time.
68 302 M20 - 85 IROC Z
scblucam is offline
'67 Camaro Dead Andrew69 Electrical & Wiring 13 Jan 28th, 19 04:51 AM
camaro 67 396 E85 EFI or carburator ? lolo3198 EFI in your modern Classic 7 Jan 5th, 19 02:22 AM
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 08:32 PM
Vintage Air in non OE AC 67 Camaro Bill Bergen Heating & Cooling 9 Sep 6th, 18 06:59 PM
