144 signal stat flasher - Team Camaro Tech
post #1 of 4 (permalink) Old May 4th, 19, 05:32 PM Thread Starter
Keith
Is there a compatible two post signal flasher that will work on 68? A standard 552 will not work. Not a lot of info on this $40 part. Thanks in advance.
68redvert is offline
post #2 of 4 (permalink) Old May 4th, 19, 06:58 PM
Jon
Re: 144 signal stat flasher
chicagocorvette.net/item.php?item=12977&rc=1809
$29.95
Jon N
dyno jonn is offline
post #3 of 4 (permalink) Old May 4th, 19, 09:07 PM
Tim
From a bit of research several years ago, it looks like the following should interchange:
Turn signal flasher: Signal-Stat 144, Tung-Sol 224
Emergency 4-way flasher: Tung-Sol 552, Signal-Stat 175
That's for standard (non-RS) lights, so the turn signal flasher type may differ for RS due to load sensitivity (number of bulbs). LED bulbs require an LED-specific flasher.
Not much info available out there about these, but surprised a 552 didn't work?
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #4 of 4 (permalink) Old May 5th, 19, 08:45 PM Thread Starter
Keith
Thanks for the replies. I'll let you know how it goes.
Solid State (LED) or 552 Flasher? 69-er Electrical & Wiring 2 Apr 18th, 19 03:44 AM
Tips for removing signal lens? patman2 Electrical & Wiring 7 Sep 15th, 18 11:10 PM
Turn Signal Canceling Cam Bigfish45 Restoration Corner 2 Jul 1st, 18 04:53 PM
maiden 67 Camaro Voyage haulted by weird turn signal Loren1967 Electrical & Wiring 2 Jun 4th, 18 03:27 PM
