69 Engine won't turn Off With Tilt Column - Team Camaro Tech
 1Likes
  • 1 Post By bucko
post #1 of 4 (permalink) Old May 25th, 19, 06:02 AM Thread Starter
Probationer
I just had an issue happen with my 69 Camaro which had an LS1 engine and factory tilt steering column. I've driven the car over 6K miles with no issues and yesterday I went to turn engine of with the key in the ignition switch and the engine would not turn off. I have a battery cut off switch in the trunk and used that to shut off engine.....Help! Thanks in advance for any suggestions as to what is causing this problem!
1Rad1955 is offline
post #2 of 4 (permalink) Old May 25th, 19, 07:07 AM
Lee
Re: 69 Engine won't turn Off With Tilt Column
Check that the ignition power wire (pink wire on GM controller) to the ECM is actually getting switched off when you turn off the key.
Using the battery cut off switch to kill the engine may not be a good idea unless that switch is also disconnecting the alternator. Disconnecting the battery while the alternator is still turning will cause voltages upwards of a 100V into the electrical system. It's better to pull the fuse for the fuel pump or ECM to kill the engine.
blitzer454 is offline
post #3 of 4 (permalink) Old May 25th, 19, 07:25 AM
Jeff
yellow69RS's Avatar
Was the tilt in a different position then usual? I think the switch may be out of adjustment.
Jeff
yellow69RS is offline
post #4 of 4 (permalink) Old May 28th, 19, 05:33 AM
Kevin
Jeff
This. Try changing the angle of the tilt to see if the engine shuts off with the ignition key turned off.
yellow69RS likes this.
Never argue with an idiot; they'll only drag you down to their level, then beat you with experience.
bucko is offline
69 Tilt Steering Column harmonica connector - Terminals french69ssrs Electrical & Wiring 5 Jan 1st, 15 11:11 AM
69 tilt column in my 68 sicdog Interiors 7 Apr 5th, 08 05:46 PM
69 tilt column ? zbo2 Brakes, Suspension & Steering 1 Apr 29th, 07 07:28 AM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 12:44 PM
69 Camaro Tilt Steering Column fit in 68 Camaro..... TEAM CANADA Brakes, Suspension & Steering 5 Sep 6th, 02 07:32 PM
