68 rear harness routing - Team Camaro Tech
 2Likes
  • 1 Post By X1169
  • 1 Post By rogerh
post #1 of 5 (permalink) Old Jun 2nd, 19, 10:49 PM Thread Starter
Shawn
X1169's Avatar
Hello all, I've searched for correct routing of rear harness from where it passes through rear seat back, over wheelhouse, to trunk extension. Its not in the AIM, or Fisher Body manual. vague photos don't accurately show if it follows the inner/outer wheelhouse seam or passes through opening near dome light harness. The area I'm looking for is from the back seat to the trunk hinge. the rest ive figured out. I know there is at least 1 clip that mounts the harness to the pinchweld at the trunk floor area.....There was a 10 year old post with a link to photos, but I cant get them to open. Any help with photos of correct routing would be much appreciated. Thanks,
X1169 is offline
post #2 of 5 (permalink) Old Jun 3rd, 19, 01:52 AM
Garth
Re: 68 rear harness routing
A few pics here (post 3 & 5)...
https://www.camaros.net/forums/19-el...-wrapping.html
Garfields Maro is offline
post #3 of 5 (permalink) Old Jun 3rd, 19, 10:30 PM Thread Starter
Shawn
X1169's Avatar
Thanks Garth, those help. Still trying to find photos of the area between the trunk hinge support to the area where the harness passes through the back seat, as viewed from the rear of the car. Thanks again,
X1169 is offline
post #4 of 5 (permalink) Old Jun 3rd, 19, 10:34 PM Thread Starter
Shawn
X1169's Avatar
Sorry Garth, I did not continue through the link far enough! found the needed photo! thanks again....
Garfields Maro likes this.
X1169 is offline
post #5 of 5 (permalink) Old Jun 3rd, 19, 11:38 PM
Roger
rogerh's Avatar
Here are a few pictures I dug up. From where it drops out of the left side of the dash board to over the fender well. As you can see the wires lay in a channel above the rocker panel. There is a thick rubber/plastic cove on the wire as they lay in that channel. Then there is a metal wire cover screwed down over them. Just on the other side of the trunk divider is the dome light connecting. The one picture shows the dome light wire going up the sail panel. My car is a RS so the green wires dropping out of harness under the tail lights goes to the backup lights.
I don't know why the first picture turned but the bottom of that picture is to the right.
Roger
ID:	227439   Click image for larger version
ID:	227441   Click image for larger version
ID:	227445   Click image for larger version
ID:	227447   Click image for larger version
ID:	227451   Click image for larger version
ID:	227453   Click image for larger version
rogerh is offline
