69 Headlamps - Team Camaro Tech
 2Likes
  • 2 Post By 69-Pace
post #1 of 4 (permalink) Old Jun 24th, 19, 09:22 AM Thread Starter
Phil
69 Headlamps
I'm needing a set of replacement headlamp bulbs for my 69 Camaro. Do any of you recommend some from Advance, O'reilly or Autozone? If so, do you have a part number? I'm not interested in any kind of high tech light that I have to install relays, strains my stock electrical system or have to do any kind of modifications to my car. I rarely drive it after dark anyway. Any help would be greatly appreciated.
Bigfish45 is offline
post #2 of 4 (permalink) Old Jun 24th, 19, 10:11 AM
69-Pace's Avatar
Re: 69 Headlamps
Then you just need good old 7inch dual beams.
I use the silverstar line from SYLVANIA.
H6024 SilverStar Sealed Beam
Bigfish45 and Vega$69 like this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Jun 24th, 19, 10:36 AM Thread Starter
Phil
Re: 69 Headlamps
Thank you very much.
post #4 of 4 (permalink) Old Jun 24th, 19, 12:24 PM
69-Pace's Avatar
Re: 69 Headlamps
No problem. They are the best OEM style headlamps in terms of both life and amount of light for the power used.
Otherwise LED's sip power but do require (most of them) some modifications to hold the lamps but not all.
Halogen lights did use more power and required relays for optimal use. These were easy acquire, and to install as they were sold often as a ready to plug-n-play kit mostly on-line.
69-Pace is offline
