Auto Meter Gauges for LS Engines - Team Camaro Tech
 4Likes
post #1 of 31 (permalink) Old Oct 29th, 19, 07:36 AM Thread Starter
majj
Hey guys, been trying to reach AutoMeter to help figure out my Speedometer issue, but haven't heard back yet for a while. I purchased their Ultra Light gauges, and was informed by the sales rep to purchase this "LS Install Kit" specifically done for LS Engines.
https://www.autometer.com/ls-install-kit.html
After installing, all gauges are functioning, except for the speedometer KM/H, reading is way off.. Jumps to 170KM/H while rolling at 10KMH lol.
Now I'm thinking maybe the rep forgot to inform me on another kit for a speedo? I found these other two LS kits on their website, but it only mentions Tacho & RPM. Thoughts?
https://www.autometer.com/ls-plug-pl...r-harness.html
https://www.autometer.com/ls-plug-pl...h-adapter.html
I'll update once I hear back from them (good to know if you ever decide to get the gauges on your LS)
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is online now
post #2 of 31 (permalink) Old Oct 29th, 19, 11:09 AM
Vega$69's Avatar
Re: Auto Meter Gauges for LS Engines
You need to run VSS signal to the Speedo. I don't know what LS harness you used but should have a VSS wire that would run to it. You can easily run VSS wire from the T56
https://www.summitracing.com/parts/aww-500951/
130fe likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 31 (permalink) Old Oct 29th, 19, 12:16 PM Thread Starter
majj
So I definitely need that part? Because i just got a hold of Autometer and they said no kit is needed for the speedo.
They shared this instruction, page 10-11
https://www.autometer.com/media/manual/2650-1563.pdf
Sent from my iPhone using Tapatalk
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #4 of 31 (permalink) Old Oct 29th, 19, 12:49 PM
Vega$69's Avatar
What are you using for VSS signal to the Gauge?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 31 (permalink) Old Oct 29th, 19, 01:09 PM Thread Starter
majj
Iíll check with my mechanic what he used exactly
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #6 of 31 (permalink) Old Nov 4th, 19, 02:32 AM Thread Starter
majj
Wasnít able to figure out, any tips on how to find out or what to look at?
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #7 of 31 (permalink) Old Nov 4th, 19, 05:48 AM
Vega$69's Avatar
On the gauge there is a terminal label sig. What does the wire that is on the sig terminal hooked to on the other end?
https://www.autometer.com/media/manual/2650-1164.pdf
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #8 of 31 (permalink) Old Nov 5th, 19, 08:51 AM Thread Starter
majj
Hereís what i got from autometer below. Now might be straightforward, and im just not understanding well.. but
Do they mean i press this button and hold? (Image)
And basically do the following:
1) Power off, push & hold button
2) keep holding, start car wait for pointer to hit full scale =180kmh, release
3)drive 2 miles, push & release button
4)then drive another 2 miles? .. confused from point 3 to 4
5) After 2 miles, push & release button
Did i get that correctly? Lol
Message from Autometer
ďIn order for the speedometer to read correctly in needs to be calibrated. To calibrate your electronic speedometer: With the power off, push and hold the calibration button (trip/reset button when equipped). While holding the button, start the vehicle and continue to hold the button until the pointer sweeps to full scale and stays at full scale. You may now release the button. Drive to the beginning of a pre-marked 2 mile distance and come to a stop. It does not matter how far away it is to get to this pre-marked 2 mile distance. Do NOT shut the engine off. Push and release the button. The pointer will drop to half scale. Drive the 2 mile distance. The pointer will remain at the half scale mark no matter what speed you drive. If the speedometer has a LCD display odometer, it will be normal to see it counting rapidly as it is receiving a speed signal. If you have to stop during the calibration, that is o.k.. The speedometer is simply counting pulses during this time. At the end of the 2 mile distance, come to a complete stop and push and release the button. The pointer will drop to 0 and the calibration is stored. You are now finished. Remember the accuracy of your 2 mile distance will directly affect the accuracy of your speedometerĒ
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #9 of 31 (permalink) Old Nov 5th, 19, 09:07 AM
Vega$69's Avatar
No
Press and hold while starting car.
At the start of the 2 mile measured distance push the button 1 time.
Drive the 2 mile measured distance. Any speed, stops and starts doesn't matter.
At end of 2 miles driven press button 1 time.
While you're driving the measured 2 miles you will see counting rapidly numbers (pulses) in the LCD display odometer. If the numbers are NOT counting up either you did not do the calibration correctly or the speedometer is not receiving a speed signal (wired wrong)
130fe likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 31 (permalink) Old Nov 5th, 19, 09:40 AM Thread Starter
majj
No
perfect , Iíll try that and see how it goes. Thank you!
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #11 of 31 (permalink) Old Nov 6th, 19, 04:39 AM Thread Starter
majj
So I just followed the calibration instructions, and did a video below.
When measuring the 2 miles, I used google maps and set a distance of 2 miles. (hopefully it's accurate).
Once completed, the speedometer works now, and doesn't jump to 180KMH anymore. However, I wanted to test the accuracy. I used an iPhone app "Speedometer", and another app.
I don't know how reliable and accurate both apps were, but both were reading 15-20KMH higher than my actual Speedometer.
How can I test the accuracy? Should I try to restart the whole calibration?
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #12 of 31 (permalink) Old Nov 6th, 19, 05:29 AM
Vega$69's Avatar
A few suggestions
Drive 60 mph for 1 minute and watch odometer. Will show exactly 1 mile traveled in 1 minute.
Or have someone pace you in another car and compare speeds.
The phone apps for speed are pretty accurate so most likely your measured 2 miles was not accurate.
I would drive another vehicle 2 miles to determine start/stop marks an go through the calibration process again.
majj35 likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 31 (permalink) Old Nov 6th, 19, 05:31 AM Thread Starter
majj
A few suggestions
Sounds good, will try that again until i nail it! Thanks a lot for the info
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #14 of 31 (permalink) Old Nov 7th, 19, 03:26 AM Thread Starter
majj
Measured a perfect 2 miles, again, this time on a long road. Did the whole calibration again... and itís still reading 10-15kmh lower than actual. (Speedometer app & waze)
1968 Camaro SS
LS2/T56
RideTech StreetGrip
post #15 of 31 (permalink) Old Nov 7th, 19, 04:54 AM
In following this a little i notice the conversation going between miles and km. Curious if there is a conversion or setting thats off.
3d cad is offline
Tags
auto meter, gauge console, gauges, ls install kit, ultra light
