Alternator Ground - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 2nd, 05, 03:37 AM Thread Starter
Alternator Ground
The back side of my alternator has a screw stud sticking out on lower side towards the engine. Next to this stud and cast into the alternator are the letters GND. I think I can assume GND stands for Ground but I can't figure what is suppose to attach to this stud. I have all new harnesses and the alternator is original style for a 68 Camaro. I have attached all wires in harness and there are no ground wires to attach. I know I have messed with several alternators in my life, but I do not recall ever disconnecting a ground wire from the alternator. Any help would be appreciated?
EricE
68 Butternut Yellow
SS Coupe 396/325
stope4 is offline
post #2 of 3 (permalink) Old Apr 2nd, 05, 05:39 AM
Re: Alternator Ground
Most alternators if not all will ground themselves thru the case that is mounted to the engine mounts thru hard mounts. Some alternator applications actually have hard plastic/hard rubber mounts that electrically isolate the alternator and the only way to ground it is thru the case terminal you have discovered.
You can hook this terminal up with a wire to engine ground if you want, but usually is an overkill. However, I have seen some chrome plated models have problems with gounding needing external grounding. This is because either the chrome "flash" or uneven surfaces don't quite match. This is handy when that happens.
A symptom of poor alternator grounding would be full 14VDC ish voltages at light loads and really dropping off at high loads.
Steve "Jack'stands" Jack
HOTRODSRJ is offline
post #3 of 3 (permalink) Old Apr 2nd, 05, 02:28 PM Thread Starter
Thanks! Good info!
EricE
68 Butternut Yellow
SS Coupe 396/325
stope4 is offline
