Electric Fuel Pump always on? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 6th, 05, 10:32 AM Thread Starter
I have a question for you guys (and please excuse my ignorance):
I bought an electric fuel pump for my SB 350 in my 69 Camaro and I was wondering if even when the key is only turned to ACC, for example to listen to the radio, should the electric fuel pump be running? Mine does and I think this is very strange since it will probably kill the battery in no time. Is this wired wrong or is this normal behavior?
Thanks in advance!
scalise is offline
post #2 of 5 (permalink) Old Apr 6th, 05, 10:39 AM
Bill
Re: Electric Fuel Pump always on?
I would rewire it to a toggle switch.
WildBillyT is offline
post #3 of 5 (permalink) Old Apr 6th, 05, 11:31 AM
It should not. Sounds like it it wired to accessory power and it should be wired to ignition power.
dnult is offline
post #4 of 5 (permalink) Old Apr 6th, 05, 02:22 PM
I agree......wire it to ignition power only. The ACC power should not run this.
Steve "Jack'stands" Jack
HOTRODSRJ is offline
post #5 of 5 (permalink) Old Apr 6th, 05, 03:10 PM
Vintage 68's Avatar
You should also seriously think about installing a oil pressure controlled switch in the circuit to disable the pump if the oil pressure is low or the engine is off.
This would not only fix your wiring problem, but would help prevent your car from burning-up if something happens.
Here is a past thread discussing this - https://www.camaros.net/forums/showth...el+pump+wiring
Try a search for 'fuel pump wiring' and look for others.
1968 Convertible
Some trucks
Vintage 68 is offline
where do I mount my electric fuel pump? grf68 Performance 3 Mar 30th, 04 03:06 AM
Fuel pump: from electric to mechanical fredbear04 Tech 2003 1 Dec 15th, 03 01:38 AM
mounting electric fuel pump??? BBCamaro Performance 6 Feb 9th, 03 09:51 PM
electric pump pumbing to a stock fuel tank Oncea3Fan Performance 8 Sep 10th, 02 04:54 PM
fuel pump bad? nasadude Troubleshooting 4 Dec 3rd, 01 06:49 PM
