CS120 Wiring HELP! - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 8th, 05, 04:18 PM Thread Starter
CS120 Wiring HELP!
I recently swapped over to the late model CS120. I am having some problems figuring out exactly where to connect the wires! The aftermarket plug that I bought only has 3 wires coming out of it.. A heavy gauge red, a thinner gauge brown and a black. I read the tech reference:
On the connector that I got, there were four wires and the body of the connector had identification letters. Here are the id letters and the color wires (don't count on the colors to be the same as what you get).
"S", this was a heavy gauge, red wire.
"F", this was a small gauge, brown wire.
"L", this was a small gauge, brown/red wire.
"P", this was a small gauge, brown/white wire.
The red wire from "S" gets connected back to the output terminal of the alternator just like in the "SI" swap.
The brown/red wire from "L" gets connected to what is shown in the diagram above as the blue wire. It's this wire that comes (indirectly) from the idiot light and it energizes the alternator.
The wires from "F" and "P" are not used!
....and can't seem to figure out how to wire this thing up! I see that my red wire goes back to the charging post on the back of the alternator-easy enough. The problem comes from the other two wires... My connector has "S" "F" "L" "P" marked on it, but only has three wires. The brown wire comes out of the connector right between the "F" & "L"!!!! Can someone please tell me what these other two wires go to!
1969 383CI, T-56, 12 bolt-3.31 posi, 13" C5 Rotors, PBR Calipers, rear disc system..
Go69 is offline
post #2 of 5 (permalink) Old Apr 8th, 05, 06:49 PM
Re: CS120 Wiring HELP!
It sounds like you are describing the regulator bypass plug. If you pull the connector off the reg (drivers side of rad support, black box) does your new connector fit the reg's harness plug?
post #3 of 5 (permalink) Old Apr 9th, 05, 07:28 AM Thread Starter
No, not a regulator bypass plug. My car has no external regulator, nor the wiring for the external regulator. All of that stuff was removed before I bought the car.
I should have stated in my first post, it is the alternator plug that I am trying to figure out. I now know that the only other wire I need to hook up is the "L" wire. I know that the "L" wire gets hooked up to the "Batt" light in my dash. I simply need to know where the wire for the "BATT" light comes through the wiring harness into the engine compartment so that I can tie it to the "L" wire coming from the alternator and I should be finished!
Does anyone have a wiring diagram for a '69? I think I need both the engine side, and the under dash side! Thank you!
Go69 is offline
post #4 of 5 (permalink) Old Apr 9th, 05, 07:41 AM
Guess
HwyStarJoe's Avatar
Exclamation Re: CS120 Wiring HELP!
HwyStarJoe is offline
post #5 of 5 (permalink) Old Apr 9th, 05, 11:51 AM
hook the brown wire coming out of the alt plug to whatever wire goes to the idiot light, loop the red wire to the back of the alt, run a hefty wire from the back post of the alt directly to the + terminal on the battery (use the biggest wire you can find- the stock wiring isn't big enough for the power this alt can put out) and tape off the extra wires that are for late model cars that control the charging with the ecm.
easy enough, eh?
you don't plan sincerity.
novaderrik is offline
Wiring help needed!! GDV350SS Electrical & Wiring 5 Jul 9th, 03 06:36 AM
67 or later AC wiring and suitcase gasmoney Electrical & Wiring 1 Jan 21st, 03 09:42 AM
engine wiring harness, extra wire? tdpole Electrical & Wiring 15 Jan 30th, 02 05:34 AM
Wiring Diagram ohayden Electrical & Wiring 9 Dec 30th, 01 02:58 PM
wiring for idiont lights vs z28 guage clusters (swapping) Chuck78 Electrical & Wiring 3 Jan 6th, 01 08:47 AM
