my camaro wont start help - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 15th, 05, 03:21 PM Thread Starter
i have a 93 z28 camaro thats sick, the car would start you could drive as long as you wanted but when you cut it off it may not start and sometimes it would start, i replaced the ignition switch but no help , now it wont do nothing, the security box in the dash i can cross 2 wires over and it will start and run for a 5 seconds and shuts off or i can keep pumping the gas and it will run but back fire, if i dont cross the wires it seems to not have power to the starter, every thing else works lights windows dash lights radio but wont start can any body help
leonard is offline
post #2 of 2 (permalink) Old Apr 15th, 05, 03:41 PM
Harry
dawg's Avatar
Re: my camaro wont start help
common problem.
its called starter heat soak.
get a starter heat sheild or replace starter.
434 stroker
US Navy retired
dawg is offline
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 08:37 AM
84 Camaro hard to start when engine cold CZ Engine 3 Aug 19th, 04 02:47 AM
camaro wont start after tremec install jks67SS396 Engine 26 Feb 12th, 03 06:04 PM
68 Camaro refuses to start rodsters Troubleshooting 1 Jun 2nd, 02 01:08 PM
89 camaro 2.8 v6 wont start when hot [email protected] Troubleshooting 4 Jan 20th, 02 07:14 PM
