How do you test a horn. - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 17th, 05, 05:58 AM Thread Starter
I have the two horn setup on my 68, one horn has the tab broken off. I want to test both to see if thay are good. can you just apply 12 volts to the tab and should the horn work?
Ray
ray moore is offline
post #2 of 4 (permalink) Old Apr 17th, 05, 07:21 AM
Jonesy's Avatar
Re: How do you test a horn.
There should be a spade lug that the wire goes to on the horn, that gets the pos connection and then the bracket gets ground.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #3 of 4 (permalink) Old Apr 20th, 05, 04:37 AM Thread Starter
If you apply the 12 volts should the horn blow as normal?
post #4 of 4 (permalink) Old Apr 20th, 05, 07:36 AM
click's Avatar
Yes
click is offline
'69 Horn Question redlines4us Electrical & Wiring 39 Jun 10th, 09 11:31 AM
'69 Horn Contact/Shroud w/Tilt Column PaceCarNut Electrical & Wiring 6 Jan 8th, 05 01:37 PM
How Do I Test A Horn Relay? Pacecarjeff Electrical & Wiring 2 Oct 4th, 04 07:20 PM
Horn won't sound! chassisboy Electrical & Wiring 2 Feb 7th, 04 01:18 PM
Horn relay problems 69 Blk69 Electrical & Wiring 4 Dec 2nd, 01 05:10 PM
