turn signals not working - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 17th, 05, 10:10 PM Thread Starter
The turn signals on my 68 don't work, also my back-up lights don't work.I turned the hazards on and they work.I turn my alarm on and the lights work.Both filimants are lighting ,so I don't think it's a ground issue.The fuse is good,12volts on both sides.I replaced the signal flasher.On a wiring diagram there's a pink wire coming off the fuse that runs the turn signals and the back-up lights.Could have that wire become detached from the fuse? I've never seen the back of a fuse block so I don't know how the wires are attached.
kool is offline
post #2 of 2 (permalink) Old Apr 18th, 05, 05:51 PM
Brandon
Re: turn signals not working
Check to see that the pink wire has power. It will go to the NSS at the base of the shifter on a auto, or to a RS located on or near the reverse arm on a manual. It leaves as a green wire on both back to the reverse lights. If you've got power on the wire with ignition sw on, check at either the NSS or the RS that power still exists. Put the tranny in Reverse and check the green wire for power. If no power then likely culprit is a bad NSS or RS.
As for the turn signals, Trace the wire up to the signal switch checking for power. Then activate switch to either right or left and verify power going to the flasher module. May be a bad wire or a bad signal switch. If you got power to the Module, make sure the connections are good.
Brandon J. licence 1NASTY67
Nantooch is offline
4 way flashers work but turn signals don't HELP PERKS67-396 Electrical & Wiring 11 Jun 24th, 15 09:37 PM
Can't figure out turn signals!! scalise Electrical & Wiring 1 Feb 10th, 02 07:56 AM
BRAKE lights OUT when USING THE TURN SIGNALS KED67 Electrical & Wiring 5 Jun 26th, 01 04:40 PM
Turn signals not working on 68 camaro. Eric1 Troubleshooting 8 Mar 17th, 01 10:42 AM
No Front Turn signals? JC69RSZ28 Troubleshooting 1 Nov 13th, 00 02:51 PM
