What are these Items? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 19th, 05, 11:41 PM Thread Starter
Jerry
19HoosierDaddies67's Avatar
Send a message via MSN to 19HoosierDaddies67
In the pictures below is a unit that mounts below the voltage regulator, also there is a small barrel that mounts to the side of the voltage regulator and connects through a black wire to a connection on the VR. The unit(Delco Remy) that mounts below the voltage regulator has two push on connectors, one with a black wire and one with a green, also has a red(hot) wire connected to a screw terminal and two black wires connected to the other screw terminal. The top says Delco Remy made in the USA, and I labeled in sharpie the colors. I guess I need to know because my generator light stays on when the car is running, I have already replaced the Alternator and the Voltage regulator and it is still on. I am thinking these two items may need to be replaced as well as soon as I find out what they are. Thanks in advance.
1967 Convertible Camaro
Member of Cool Runnin Camaros:
19HoosierDaddies67 is offline
post #2 of 5 (permalink) Old Apr 19th, 05, 11:59 PM
Harry
dawg's Avatar
Re: What are these Items?
the 2 top pics are the capacitors.
used in radio noise interference.
the bottom pics are your horn relay also has charging circuit wiring going through it.
replace both too be certain they are good .
horn relay especially.
itll save you a few headaches later on.
434 stroker
US Navy retired
dawg is offline
post #3 of 5 (permalink) Old Apr 20th, 05, 12:24 AM Thread Starter
Jerry
Thanks Dawg, would either of these have anything to do with the Generator light staying on, it doesn't sound like either would.
post #4 of 5 (permalink) Old Apr 20th, 05, 03:16 AM
Harry
dawg's Avatar
well it might be the horn relay seeing that part of your charging circuit goes through it.
but I would also check the regulator ( big electical box above horn relay)
if its not a heavy duty regulator you problem is most likely there.
I know this cause I had same problem years ago and it ended up being the regulator.
judging by all the corrosion on all those items i would spend a few bucks and replace them.
434 stroker
US Navy retired
dawg is offline
post #5 of 5 (permalink) Old Apr 20th, 05, 05:23 PM
Looking at the pics, the regulator looks like a solid state replacement unit. Little green circuit board instead of coils and contacts. The semi-conductors on the board can be damaged easily if it wasn't wired properly. Check all the associated wiring for breaks, shorts, and correct terminal placement before you attempt to put a new one on.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
Items 81vettefreak Camaros.net Site Help Discussion 2 Aug 31st, 04 03:02 AM
Refinishing items in engine compartment. Indy Z11 Restoration Corner 10 Apr 26th, 04 04:22 PM
How to transfer funds & ship items for a big ticket item? knipper Bench Racing 6 Mar 11th, 04 06:36 PM
Strange items found in Camaros cavemate Bench Racing 38 Jan 7th, 02 06:11 PM
Availability of various interior items.... Mayhemm Interiors 5 Oct 18th, 00 07:08 PM
